Date/Time: Wed, 27 Nov 2024 00:31:09 +0000
Measured move
View Count: 477
[2023-09-27 16:10:02]
User904644 - Posts: 9
Is there a tool for measured move? I have been through all of them. Am I missing something?
Thanks,
Bruce
[2023-09-27 16:10:21]
John - SC Support - Posts: 36309
We need more information on what exactly you are looking for in terms of a "Measured Move".
[2023-09-29 14:38:57]
This diagram I hope explains what I am looking to measure.
Private File
[2023-10-02 09:23:46]
Sierra_Chart Engineering - Posts: 17187
No Sierra Chart does not have this tool. There is the Chart Calculator tool:
Chart Drawing Tools: Chart Calculator
But it is not going to include the length of two lines like that.
[2023-10-03 13:13:46]
caligola - Posts: 116
If you are looking for an AB=CD tool, you can use the Price Projection Tool with 2 levels: 0 and 100%.
Chart Drawing Tools: Price Retracement | Price Expansion | Price Projection Configuration
[2023-10-03 14:53:09]
If that Drawing Tool works for you that would be good.
[2023-10-03 17:10:43]
Sawtooth - Posts: 4120
Use the Price Retracement tool with settings in the attached pic.
imagePrice Retracement config for Measured Move.PNG / V - Attached On 2023-10-03 17:10:33 UTC - Size: 21.08 KB - 109 views
