Date/Time: Wed, 27 Nov 2024 03:52:20 +0000
Can you position all the MDI tabs to the center of screen?
View Count: 254
[2023-09-27 12:54:34] |
mojsterr - Posts: 26 |
Right now the MDI tabs are to the left. Is it somehow possible to reposition them, so they would be in the center of my screen instead? I know one option is to make a new MDI tab on the left side and put a lot of underscores in its name, which would move all of them more right, but I was wondering if there is a better way. Thank you. |
[2023-09-27 15:40:06] |
John - SC Support - Posts: 36309 |
There is not a way to center the MDI Tabs. The only options for the MDI tabs (apart from colors) are defined at the following link: General Settings Window: Window Tabs (Global Settings >> General Settings >> Windows) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
