Date/Time: Wed, 27 Nov 2024 03:45:30 +0000
After switching to Teton, CME data is not coming
View Count: 189
[2023-09-27 12:18:23] |
User973745 - Posts: 13 |
Hi, I switched to Teton from CGQ and now not receiving data from CME, only forex |
[2023-09-27 12:19:32] |
Sierra_Chart Engineering - Posts: 17190 |
You need to translate the symbols with this Edit menu command: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
