Date/Time: Wed, 27 Nov 2024 03:40:52 +0000
numbers bars calculated values
View Count: 200
[2023-09-27 12:17:54] |
User220939 - Posts: 36 |
Bonjour, Dans l'étude numbers bars calculated values, dans la section subgraph pourriez vous me dire comment interpréter le ligne SG3 (ask volume bid volume différence change)? Merci |
[2023-09-27 15:18:39] |
John - SC Support - Posts: 36309 |
From Google Translate: In the numbers bars calculated values study, in the subgraph section could you tell me how to interpret the SG3 line (ask volume bid volume difference change)?
You will find the descriptions for all the subgraphs in the Numbers Bars Calculated Values starting at the following link: Numbers Bars: Numbers Bars Calculated Values Subgraph Descriptions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
