Date/Time: Wed, 27 Nov 2024 03:37:03 +0000
Trading Evaluator: Secondary instance is not allowing connections to this server
View Count: 285
[2023-09-27 09:48:56]
User733263 - Posts: 7
Having issues connecting through Trading Evaluator.
All other connections seems to work without any issues
Copy/pasting the log here:
Trading Evaluator | Connecting to the server tradesimulation4.sierracharts.com. Port 11096 | 2023-09-27 05:46:15.498
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-27 05:46:15.499
DTC Client socket (1) | New receive buffer size: 0 | 2023-09-27 05:46:15.499
DTC Client socket (1) | Connecting to IP: 162.251.232.244. | 2023-09-27 05:46:15.499
Trading Evaluator | Network connection to server complete. | 2023-09-27 05:46:15.630
Trading Evaluator | Starting socket receive thread. | 2023-09-27 05:46:15.630
Trading Evaluator | Sending encoding request to server: Binary VLS. Compression: none | 2023-09-27 05:46:15.631
Trading Evaluator | Setting DTC encoding to Binary VLS | 2023-09-27 05:46:16.017
Trading Evaluator | Sending logon request message. | 2023-09-27 05:46:16.017
Trading Evaluator | Received logon response. | 2023-09-27 05:46:16.148
Trading Evaluator | Server Name: SC DTC Server. | 2023-09-27 05:46:16.148
Trading Evaluator | Server protocol version: 8. Client protocol version: 8 | 2023-09-27 05:46:16.148
Trading Evaluator | Logon error received from server: Secondary instance is not allowing connections to this server | 2023-09-27 05:46:16.148
Trading Evaluator | Failed connections: 121 | 2023-09-27 05:46:16.148
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-27 05:46:16.148
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 05:46:16.148
Trading Evaluator | Waiting for socket receive thread to end | 2023-09-27 05:46:16.169
DTC Client socket (1) | CloseSocket call. | 2023-09-27 05:46:16.171
Trading Evaluator | Disconnected. | 2023-09-27 05:46:16.171
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 05:46:16.171
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-09-27 05:46:16.171
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-09-27 05:46:16.303
DTC Client socket (1) | Closed. | 2023-09-27 05:46:16.303
Date Time Of Last Edit: 2023-09-27 09:49:42
imageScreen Shot 27-09-2023 at 10.48.png / V - Attached On 2023-09-27 09:48:29 UTC - Size: 34.74 KB - 59 views
[2023-09-27 10:03:15]
Sierra_Chart Engineering - Posts: 17190
We are checking on this now.
[2023-09-27 10:32:05]
I just verified. The connection seems to be working for now. Will continue to monitor and report back if there are any issues.
Thank you support team.
Regards,
[2023-09-27 15:15:15]
John - SC Support - Posts: 36309
This was resolved last night.
