Date/Time: Sat, 19 Apr 2025 09:45:11 +0000
How does pulling / stacking column is calculated?
View Count: 421
[2023-09-27 09:24:14]
BenjFlame - Posts: 337
can you please describe or send to a page (didn't found one) explaining how pulling / stacking dom column works?
When an ask row, has let's say 2000 shares, then shows 2100, I would have expected pulling stacking to show 100, but it shows 2100.
[2023-09-27 14:43:24]
John - SC Support - Posts: 39362
It should show as you expect. It is just the difference in the quantity of orders at that price.
We did see an issue recently with the pulling/stacking for equity symbols that we are still looking into. What is the symbol for the chart where you saw this?
[2023-09-27 20:14:40]
I don't remember the symbol but i'm pretty sure it does it on all _MBO symbols. Look into small priced ones, in the range of $1 - $10
[2023-09-27 20:26:56]
This is being worked on.
[2023-09-29 13:44:54]
Sierra_Chart Engineering - Posts: 19276
We have now determined that pulling and stacking calculations are definitively inaccurate with _MBO symbols. Do not use this functionality with those symbols. This is not something that we can reasonably resolve.
[2025-03-19 10:38:38]
are the stocks _mbo pulling and stacking calculations still innacurate ? Or was it resolved ?
[2025-03-19 14:09:53]
It is still the case that the Pulling/Stacking for _MBO symbols will not be correct.
[2025-03-19 15:05:30]
This will never change. There is no resolution to this and never will be.
