Date/Time: Tue, 03 Nov 2026 09:34:29 +0000
[Programming Help] - DRAWING_RECTANGLE_EXT_HIGHLIGHT or DRAWING_RECTANGLEHIGHLIGHT - Center Text Vertically
View Count: 1598
[2023-09-27 05:06:34]
User907967 - Posts: 54
Suppose I create a new drawing (DRAWING_RECTANGLE_EXT_HIGHLIGHT or DRAWING_RECTANGLEHIGHLIGHT), apply a text, click on its properties and select Center Text Vertically. In that case, that text will appear at half the vertical distance between its BeginValue and EndValue (i.e., its Y coordinates). Great.
How do I get that text to appear in the same position if I use s_UseTool ? The below does not work.
s_UseTool Tool;
Tool.Clear();
Tool.Text = Text;
Tool.TextAlignment = DT_VCENTER | DT_CENTER;
Tool.AddMethod = UTAM_ADD_OR_ADJUST;
Tool.DrawingType = DRAWING_RECTANGLE_EXT_HIGHLIGHT;
// Tool.DrawingType = DRAWING_RECTANGLEHIGHLIGHT;
Tool.BeginValue = Value1;
Tool.EndValue = Value2;
sc.UseTool(Tool);
Thank you.
