Date/Time: Wed, 27 Nov 2024 03:41:40 +0000
Trading Evaluator: Secondary instance is not allowing connection to this server
View Count: 324
[2023-09-27 04:56:16]
RevenueStream - Posts: 2
I tried three different accounts I use with SC all connect no problem, more importantly I tried Trade evaluator delayed data and this service connects no problem.
Something I notice when I select --> Trade --> Trade Account Monitor/Balances Window in order to view the corresponding account I setup for the Trade Evaluator the account which is shown is the account from the previous connected account which was selected from Data/Trade Service Settings.
I also tried --> File --> Disconnect then File--> Reconnect
Trading Evaluator | Connecting to the server tradesimulation4.sierracharts.com. Port 11096 | 2023-09-26 21:35:40.380
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-26 21:35:40.380
DTC Client socket (1) | New receive buffer size: 0 | 2023-09-26 21:35:40.381
DTC Client socket (1) | Connecting to IP: 162.251.232.244. | 2023-09-26 21:35:40.381
Trading Evaluator | Network connection to server complete. | 2023-09-26 21:35:40.416
Trading Evaluator | Starting socket receive thread. | 2023-09-26 21:35:40.416
Trading Evaluator | Sending encoding request to server: Binary VLS. Compression: none | 2023-09-26 21:35:40.416
Trading Evaluator | Setting DTC encoding to Binary VLS | 2023-09-26 21:35:40.519
Trading Evaluator | Sending logon request message. | 2023-09-26 21:35:40.519
Trading Evaluator | Received logon response. | 2023-09-26 21:35:40.552
Trading Evaluator | Server Name: SC DTC Server. | 2023-09-26 21:35:40.552
Trading Evaluator | Server protocol version: 8. Client protocol version: 8 | 2023-09-26 21:35:40.552
Trading Evaluator | Logon error received from server: Secondary instance is not allowing connections to this server | 2023-09-26 21:35:40.552
Trading Evaluator | Failed connections: 87 | 2023-09-26 21:35:40.552
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-26 21:35:40.552
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-26 21:35:40.552
Trading Evaluator | Waiting for socket receive thread to end | 2023-09-26 21:35:40.566
DTC Client socket (1) | CloseSocket call. | 2023-09-26 21:35:40.567
Trading Evaluator | Disconnected. | 2023-09-26 21:35:40.567
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-26 21:35:40.567
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-09-26 21:35:40.567
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-09-26 21:35:40.603
DTC Client socket (1) | Closed. | 2023-09-26 21:35:40.603
Trading Evaluator | Connecting to the server tradesimulation2.sierracharts.com. Port 11096 | 2023-09-26 21:35:42.570
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-26 21:35:42.570
DTC Client socket (1) | New receive buffer size: 0 | 2023-09-26 21:35:42.571
DTC Client socket (1) | Connecting to IP: 142.215.17.188. | 2023-09-26 21:35:42.571
ESZ23 [CB][M] 240 Min #7 | StartDateTimeForLoadingOrderFills: 2023-06-14 00:00:00 | 2023-09-26 21:35:42.724
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-09-26 21:35:45.017 *
DTC Client socket (1) | CloseSocket call. | 2023-09-26 21:35:45.017
Trading Evaluator | Failed connections: 88 | 2023-09-26 21:35:45.017
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-26 21:35:45.017
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-26 21:35:45.017
DTC Client socket (1) | Closed. | 2023-09-26 21:35:45.017
DTC Client socket (0) | CloseSocket call. | 2023-09-26 21:35:45.027
Trading Evaluator | Disconnected. | 2023-09-26 21:35:45.027
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-26 21:35:45.027
ESZ23 [CB][M] 240 Min #7 | StartDateTimeForLoadingOrderFills: 2023-06-14 00:00:00 | 2023-09-26 21:35:45.227
Trading Evaluator | Connecting to the server tradesimulation4.sierracharts.com. Port 11096 | 2023-09-26 21:35:47.030
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-26 21:35:47.031
DTC Client socket (1) | New receive buffer size: 0 | 2023-09-26 21:35:47.031
DTC Client socket (1) | Connecting to IP: 162.251.232.244. | 2023-09-26 21:35:47.031
Trading Evaluator | Network connection to server complete. | 2023-09-26 21:35:47.064
Trading Evaluator | Starting socket receive thread. | 2023-09-26 21:35:47.064
Trading Evaluator | Sending encoding request to server: Binary VLS. Compression: none | 2023-09-26 21:35:47.064
Trading Evaluator | Setting DTC encoding to Binary VLS | 2023-09-26 21:35:47.174
Trading Evaluator | Sending logon request message. | 2023-09-26 21:35:47.174
Trading Evaluator | Received logon response. | 2023-09-26 21:35:47.213
Trading Evaluator | Server Name: SC DTC Server. | 2023-09-26 21:35:47.213
Trading Evaluator | Server protocol version: 8. Client protocol version: 8 | 2023-09-26 21:35:47.213
Trading Evaluator | Logon error received from server: Secondary instance is not allowing connections to this server | 2023-09-26 21:35:47.213
Trading Evaluator | Failed connections: 89 | 2023-09-26 21:35:47.213
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-26 21:35:47.213
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-26 21:35:47.213
Trading Evaluator | Waiting for socket receive thread to end | 2023-09-26 21:35:47.234
DTC Client socket (1) | CloseSocket call. | 2023-09-26 21:35:47.235
Trading Evaluator | Disconnected. | 2023-09-26 21:35:47.235
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-26 21:35:47.235
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-09-26 21:35:47.235
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-09-26 21:35:47.270
DTC Client socket (1) | Closed. | 2023-09-26 21:35:47.270
Trading Evaluator | Connecting to the server tradesimulation2.sierracharts.com. Port 11096 | 2023-09-26 21:35:49.237
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-26 21:35:49.240
DTC Client socket (1) | New receive buffer size: 0 | 2023-09-26 21:35:49.240
DTC Client socket (1) | Connecting to IP: 142.215.17.188. | 2023-09-26 21:35:49.240
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-09-26 21:35:51.774 *
DTC Client socket (1) | CloseSocket call. | 2023-09-26 21:35:51.775
Trading Evaluator | Failed connections: 90 | 2023-09-26 21:35:51.775
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-26 21:35:51.775
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-26 21:35:51.775
DTC Client socket (1) | Closed. | 2023-09-26 21:35:51.775
DTC Client socket (0) | CloseSocket call. | 2023-09-26 21:35:51.784
Trading Evaluator | Disconnected. | 2023-09-26 21:35:51.784
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-26 21:35:51.784
Trading Evaluator | Connecting to the server tradesimulation4.sierracharts.com. Port 11096 | 2023-09-26 21:35:53.787
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-26 21:35:53.787
DTC Client socket (1) | New receive buffer size: 0 | 2023-09-26 21:35:53.787
DTC Client socket (1) | Connecting to IP: 162.251.232.244. | 2023-09-26 21:35:53.787
Trading Evaluator | Network connection to server complete. | 2023-09-26 21:35:53.821
Trading Evaluator | Starting socket receive thread. | 2023-09-26 21:35:53.821
Trading Evaluator | Sending encoding request to server: Binary VLS. Compression: none | 2023-09-26 21:35:53.821
Trading Evaluator | Setting DTC encoding to Binary VLS | 2023-09-26 21:35:53.927
Trading Evaluator | Sending logon request message. | 2023-09-26 21:35:53.927
Trading Evaluator | Received logon response. | 2023-09-26 21:35:53.964
Trading Evaluator | Server Name: SC DTC Server. | 2023-09-26 21:35:53.964
Trading Evaluator | Server protocol version: 8. Client protocol version: 8 | 2023-09-26 21:35:53.964
Trading Evaluator | Logon error received from server: Secondary instance is not allowing connections to this server | 2023-09-26 21:35:53.964
Trading Evaluator | Failed connections: 91 | 2023-09-26 21:35:53.964
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-26 21:35:53.964
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-26 21:35:53.964
Trading Evaluator | Waiting for socket receive thread to end | 2023-09-26 21:35:54.014
DTC Client socket (1) | CloseSocket call. | 2023-09-26 21:35:54.015
Trading Evaluator | Disconnected. | 2023-09-26 21:35:54.015
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-26 21:35:54.015
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-09-26 21:35:54.015
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-09-26 21:35:54.047
DTC Client socket (1) | Closed. | 2023-09-26 21:35:54.047
Trading Evaluator | Connecting to the server tradesimulation2.sierracharts.com. Port 11096 | 2023-09-26 21:35:56.010
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-26 21:35:56.010
DTC Client socket (1) | New receive buffer size: 0 | 2023-09-26 21:35:56.010
DTC Client socket (1) | Connecting to IP: 142.215.17.188. | 2023-09-26 21:35:56.010
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-09-26 21:35:58.462 *
DTC Client socket (1) | CloseSocket call. | 2023-09-26 21:35:58.463
Trading Evaluator | Failed connections: 92 | 2023-09-26 21:35:58.463
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-26 21:35:58.463
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-26 21:35:58.463
DTC Client socket (1) | Closed. | 2023-09-26 21:35:58.463
DTC Client socket (0) | CloseSocket call. | 2023-09-26 21:35:58.485
Trading Evaluator | Disconnected. | 2023-09-26 21:35:58.485
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-26 21:35:58.485
Trading Evaluator | Connecting to the server tradesimulation4.sierracharts.com. Port 11096 | 2023-09-26 21:36:00.478
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-26 21:36:00.478
DTC Client socket (1) | New receive buffer size: 0 | 2023-09-26 21:36:00.478
DTC Client socket (1) | Connecting to IP: 162.251.232.244. | 2023-09-26 21:36:00.478
Trading Evaluator | Network connection to server complete. | 2023-09-26 21:36:00.583
Trading Evaluator | Starting socket receive thread. | 2023-09-26 21:36:00.583
Trading Evaluator | Sending encoding request to server: Binary VLS. Compression: none | 2023-09-26 21:36:00.583
Trading Evaluator | Setting DTC encoding to Binary VLS | 2023-09-26 21:36:00.689
Trading Evaluator | Sending logon request message. | 2023-09-26 21:36:00.689
Trading Evaluator | Received logon response. | 2023-09-26 21:36:00.725
Trading Evaluator | Server Name: SC DTC Server. | 2023-09-26 21:36:00.725
Trading Evaluator | Server protocol version: 8. Client protocol version: 8 | 2023-09-26 21:36:00.725
Trading Evaluator | Logon error received from server: Secondary instance is not allowing connections to this server | 2023-09-26 21:36:00.725
Trading Evaluator | Failed connections: 93 | 2023-09-26 21:36:00.725
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-26 21:36:00.725
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-26 21:36:00.725
Trading Evaluator | Waiting for socket receive thread to end | 2023-09-26 21:36:00.741
DTC Client socket (1) | CloseSocket call. | 2023-09-26 21:36:00.741
Trading Evaluator | Disconnected. | 2023-09-26 21:36:00.741
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-26 21:36:00.741
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-09-26 21:36:00.741
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-09-26 21:36:00.774
DTC Client socket (1) | Closed. | 2023-09-26 21:36:00.774
Trading Evaluator | Connecting to the server tradesimulation2.sierracharts.com. Port 11096 | 2023-09-26 21:36:02.745
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-26 21:36:02.746
DTC Client socket (1) | New receive buffer size: 0 | 2023-09-26 21:36:02.746
DTC Client socket (1) | Connecting to IP: 142.215.17.188. | 2023-09-26 21:36:02.746
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-09-26 21:36:05.112 *
DTC Client socket (1) | CloseSocket call. | 2023-09-26 21:36:05.113
Trading Evaluator | Failed connections: 94 | 2023-09-26 21:36:05.113
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-26 21:36:05.113
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-26 21:36:05.113
DTC Client socket (1) | Closed. | 2023-09-26 21:36:05.113
DTC Client socket (0) | CloseSocket call. | 2023-09-26 21:36:05.137
Trading Evaluator | Disconnected. | 2023-09-26 21:36:05.138
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-26 21:36:05.138
Trading Evaluator | Connecting to the server tradesimulation4.sierracharts.com. Port 11096 | 2023-09-26 21:36:07.131
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-26 21:36:07.132
DTC Client socket (1) | New receive buffer size: 0 | 2023-09-26 21:36:07.132
DTC Client socket (1) | Connecting to IP: 162.251.232.244. | 2023-09-26 21:36:07.132
Trading Evaluator | Network connection to server complete. | 2023-09-26 21:36:07.169
Trading Evaluator | Starting socket receive thread. | 2023-09-26 21:36:07.169
Trading Evaluator | Sending encoding request to server: Binary VLS. Compression: none | 2023-09-26 21:36:07.169
Trading Evaluator | Setting DTC encoding to Binary VLS | 2023-09-26 21:36:07.280
Trading Evaluator | Sending logon request message. | 2023-09-26 21:36:07.280
Trading Evaluator | Received logon response. | 2023-09-26 21:36:07.316
Trading Evaluator | Server Name: SC DTC Server. | 2023-09-26 21:36:07.316
Trading Evaluator | Server protocol version: 8. Client protocol version: 8 | 2023-09-26 21:36:07.316
Trading Evaluator | Logon error received from server: Secondary instance is not allowing connections to this server | 2023-09-26 21:36:07.316
Trading Evaluator | Failed connections: 95 | 2023-09-26 21:36:07.316
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-26 21:36:07.316
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-26 21:36:07.316
Trading Evaluator | Waiting for socket receive thread to end | 2023-09-26 21:36:07.331
DTC Client socket (1) | CloseSocket call. | 2023-09-26 21:36:07.332
Trading Evaluator | Disconnected. | 2023-09-26 21:36:07.332
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-26 21:36:07.332
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-09-26 21:36:07.332
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-09-26 21:36:07.365
DTC Client socket (1) | Closed. | 2023-09-26 21:36:07.365
Trading Evaluator | Connecting to the server tradesimulation2.sierracharts.com. Port 11096 | 2023-09-26 21:36:09.340
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-26 21:36:09.340
DTC Client socket (1) | New receive buffer size: 0 | 2023-09-26 21:36:09.340
DTC Client socket (1) | Connecting to IP: 142.215.17.188. | 2023-09-26 21:36:09.340
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-09-26 21:36:11.736 *
DTC Client socket (1) | CloseSocket call. | 2023-09-26 21:36:11.736
Trading Evaluator | Failed connections: 96 | 2023-09-26 21:36:11.736
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-26 21:36:11.736
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-26 21:36:11.736
DTC Client socket (1) | Closed. | 2023-09-26 21:36:11.736
DTC Client socket (0) | CloseSocket call. | 2023-09-26 21:36:11.737
Trading Evaluator | Disconnected. | 2023-09-26 21:36:11.737
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-26 21:36:11.737
Trading Evaluator | Connecting to the server tradesimulation4.sierracharts.com. Port 11096 | 2023-09-26 21:36:13.740
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-26 21:36:13.740
DTC Client socket (1) | New receive buffer size: 0 | 2023-09-26 21:36:13.740
DTC Client socket (1) | Connecting to IP: 162.251.232.244. | 2023-09-26 21:36:13.740
Trading Evaluator | Network connection to server complete. | 2023-09-26 21:36:13.774
Trading Evaluator | Starting socket receive thread. | 2023-09-26 21:36:13.774
Trading Evaluator | Sending encoding request to server: Binary VLS. Compression: none | 2023-09-26 21:36:13.774
Trading Evaluator | Setting DTC encoding to Binary VLS | 2023-09-26 21:36:14.007
Trading Evaluator | Sending logon request message. | 2023-09-26 21:36:14.007
Trading Evaluator | Received logon response. | 2023-09-26 21:36:14.040
Trading Evaluator | Server Name: SC DTC Server. | 2023-09-26 21:36:14.040
Trading Evaluator | Server protocol version: 8. Client protocol version: 8 | 2023-09-26 21:36:14.040
Trading Evaluator | Logon error received from server: Secondary instance is not allowing connections to this server | 2023-09-26 21:36:14.040
Trading Evaluator | Failed connections: 97 | 2023-09-26 21:36:14.040
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-26 21:36:14.040
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-26 21:36:14.040
Trading Evaluator | Waiting for socket receive thread to end | 2023-09-26 21:36:14.065
DTC Client socket (1) | CloseSocket call. | 2023-09-26 21:36:14.066
Trading Evaluator | Disconnected. | 2023-09-26 21:36:14.066
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-26 21:36:14.066
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-09-26 21:36:14.066
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-09-26 21:36:14.098
DTC Client socket (1) | Closed. | 2023-09-26 21:36:14.099
Trading Evaluator | Connecting to the server tradesimulation2.sierracharts.com. Port 11096 | 2023-09-26 21:36:16.077
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-26 21:36:16.078
DTC Client socket (1) | New receive buffer size: 0 | 2023-09-26 21:36:16.078
DTC Client socket (1) | Connecting to IP: 142.215.17.188. | 2023-09-26 21:36:16.078
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-09-26 21:36:18.465 *
DTC Client socket (1) | CloseSocket call. | 2023-09-26 21:36:18.465
Trading Evaluator | Failed connections: 98 | 2023-09-26 21:36:18.465
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-26 21:36:18.465
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-26 21:36:18.465
DTC Client socket (1) | Closed. | 2023-09-26 21:36:18.465
DTC Client socket (0) | CloseSocket call. | 2023-09-26 21:36:18.483
Trading Evaluator | Disconnected. | 2023-09-26 21:36:18.483
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-26 21:36:18.483
Trading Evaluator | Connecting to the server tradesimulation4.sierracharts.com. Port 11096 | 2023-09-26 21:36:20.488
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-26 21:36:20.490
DTC Client socket (1) | New receive buffer size: 0 | 2023-09-26 21:36:20.491
DTC Client socket (1) | Connecting to IP: 162.251.232.244. | 2023-09-26 21:36:20.491
Trading Evaluator | Network connection to server complete. | 2023-09-26 21:36:20.527
Trading Evaluator | Starting socket receive thread. | 2023-09-26 21:36:20.527
Trading Evaluator | Sending encoding request to server: Binary VLS. Compression: none | 2023-09-26 21:36:20.528
Trading Evaluator | Setting DTC encoding to Binary VLS | 2023-09-26 21:36:20.634
Trading Evaluator | Sending logon request message. | 2023-09-26 21:36:20.634
Trading Evaluator | Received logon response. | 2023-09-26 21:36:20.671
Trading Evaluator | Server Name: SC DTC Server. | 2023-09-26 21:36:20.671
Trading Evaluator | Server protocol version: 8. Client protocol version: 8 | 2023-09-26 21:36:20.671
Trading Evaluator | Logon error received from server: Secondary instance is not allowing connections to this server | 2023-09-26 21:36:20.671
Trading Evaluator | Failed connections: 99 | 2023-09-26 21:36:20.671
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-26 21:36:20.671
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-26 21:36:20.671
Trading Evaluator | Waiting for socket receive thread to end | 2023-09-26 21:36:20.688
DTC Client socket (1) | CloseSocket call. | 2023-09-26 21:36:20.689
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-09-26 21:36:20.689
Trading Evaluator | Disconnected. | 2023-09-26 21:36:20.689
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-26 21:36:20.689
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-09-26 21:36:20.723
DTC Client socket (1) | Closed. | 2023-09-26 21:36:20.723
Trading Evaluator | Connecting to the server tradesimulation2.sierracharts.com. Port 11096 | 2023-09-26 21:36:22.692
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-26 21:36:22.693
DTC Client socket (1) | New receive buffer size: 0 | 2023-09-26 21:36:22.693
DTC Client socket (1) | Connecting to IP: 142.215.17.188. | 2023-09-26 21:36:22.693
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-09-26 21:36:25.067 *
DTC Client socket (1) | CloseSocket call. | 2023-09-26 21:36:25.067
Trading Evaluator | Failed connections: 100 | 2023-09-26 21:36:25.067
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-26 21:36:25.067
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-26 21:36:25.067
DTC Client socket (1) | Closed. | 2023-09-26 21:36:25.067
DTC Client socket (0) | CloseSocket call. | 2023-09-26 21:36:25.090
Trading Evaluator | Disconnected. | 2023-09-26 21:36:25.090
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-26 21:36:25.090
Date Time Of Last Edit: 2023-09-27 10:25:15
[2023-09-27 07:09:16]
weav - Posts: 30
same here, looks like trading evaluator data/trade service is down
[2023-09-27 07:18:35]
User641398 - Posts: 19
same here
[2023-09-27 07:28:15]
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2023-09-27 03:21:20.266
[15452] Chartbook Sharing Server | Restore Settings | Read from File 'E:\SierraChart\Data\ChartbookSharing\ChartbookSharingSettings.config' | 2023-09-27 03:21:20.371
[15452] Chartbook Sharing Server | Restore Settings | Start reading internal server states | 2023-09-27 03:21:20.377
[15452] Chartbook Sharing Server | Restore Settings | Finish reading internal server states. OK | 2023-09-27 03:21:20.377
Created the DTC Protocol server. | 2023-09-27 03:21:20.379
DTC Protocol Server listening on port 11099. | 2023-09-27 03:21:20.381
Reading Internal Order ID file. | 2023-09-27 03:21:20.381
Reading Trade Orders file. | 2023-09-27 03:21:20.461
Reading Trade Positions file. | 2023-09-27 03:21:20.465
Reading Trade Account Data files. | 2023-09-27 03:21:20.469
Software version: 2490 64-bit | 2023-09-27 03:21:20.474
Primary Thread ID: 15452 | 2023-09-27 03:21:20.474
Usage end date: 2024-04-14 | 2023-09-27 03:21:20.474
Enabled for: Sierra Chart Historical Data Service. | 2023-09-27 03:21:20.474
Enabled for: Delayed Denali Exchange Data Feed. | 2023-09-27 03:21:20.474
Enabled for exchange2: fairx_exchange.data | 2023-09-27 03:21:20.474
Allow Support for Sierra Chart Data Feeds is enabled. | 2023-09-27 03:21:20.474
Current selected Data/Trading service: Trading Evaluator | 2023-09-27 03:21:20.474
Custom symbol settings values: enabled | 2023-09-27 03:21:20.474
Chart Update Interval: 100 | 2023-09-27 03:21:20.474
Intraday Data Storage Time Unit: 1 | 2023-09-27 03:21:20.474
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2023-09-27 03:21:20.474
2023-09-27 07:21:20 Local computer time in UTC | 2023-09-27 03:21:20.474
2023-09-27 03:21:20 Local computer time in SC Time Zone | 2023-09-27 03:21:20.474
2023-09-27 07:21:16 Server time in UTC | 2023-09-27 03:21:20.474
Local computer UTC time and Server UTC time difference: 1 seconds. | 2023-09-27 03:21:20.474
Program path: E:\SierraChart\ | 2023-09-27 03:21:20.474
Data Files path: E:\SierraChart\Data\ | 2023-09-27 03:21:20.474
OS Version Number: 10.0 | 2023-09-27 03:21:20.474
Locale Setting: C | 2023-09-27 03:21:20.474
DLLs: gc5150_Studies_2431_64.dll, swing-points.dll, UserContributedStudies_64.dll, Zyp Free by Zyp_64.dll, Zyp OrderFlow by Zdislav_64.dll, Zyp Trade_Your_Plan_64.dll | 2023-09-27 03:21:20.475
Allowed protected custom studies: zyp_app | 2023-09-27 03:21:20.475
Crash reporter started: true | 2023-09-27 03:21:20.475
DTC Client socket (1) | CloseSocket call. | 2023-09-27 03:24:09.691
Trading Evaluator | Disconnected. | 2023-09-27 03:24:09.691
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 03:24:09.691
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-09-27 03:24:09.691
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-09-27 03:24:09.861
DTC Client socket (1) | Closed. | 2023-09-27 03:24:09.861
Trading Evaluator | Connecting to the server tradesimulation2.sierracharts.com. Port 11096 | 2023-09-27 03:24:11.703
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-27 03:24:11.703
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-09-27 03:24:11.703
DTC Client socket (1) | Connecting to IP: 142.215.17.188. | 2023-09-27 03:24:11.703
DTC Client socket (1) | Connect event error. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2023-09-27 03:24:14.379 *
DTC Client socket (1) | CloseSocket call. | 2023-09-27 03:24:14.394
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-27 03:24:14.394
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 03:24:14.394
DTC Client socket (1) | Closed. | 2023-09-27 03:24:14.394
DTC Client socket (0) | CloseSocket call. | 2023-09-27 03:24:14.420
Trading Evaluator | Disconnected. | 2023-09-27 03:24:14.420
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 03:24:14.420
Trading Evaluator | Connecting to the server tradesimulation4.sierracharts.com. Port 11096 | 2023-09-27 03:24:16.412
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-27 03:24:16.412
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-09-27 03:24:16.412
DTC Client socket (1) | Connecting to IP: 162.251.232.244. | 2023-09-27 03:24:16.412
Trading Evaluator | Network connection to server complete. | 2023-09-27 03:24:16.592
Trading Evaluator | Starting socket receive thread. | 2023-09-27 03:24:16.592
Trading Evaluator | Sending encoding request to server: Binary VLS. Compression: none | 2023-09-27 03:24:16.592
Trading Evaluator | Setting DTC encoding to Binary VLS | 2023-09-27 03:24:17.100
Trading Evaluator | Sending logon request message. | 2023-09-27 03:24:17.100
Trading Evaluator | Received logon response. | 2023-09-27 03:24:17.267
Trading Evaluator | Server Name: SC DTC Server. | 2023-09-27 03:24:17.267
Trading Evaluator | Server protocol version: 8. Client protocol version: 8 | 2023-09-27 03:24:17.267
Trading Evaluator | Logon error received from server: Secondary instance is not allowing connections to this server | 2023-09-27 03:24:17.267
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-27 03:24:17.267
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 03:24:17.267
Trading Evaluator | Waiting for socket receive thread to end | 2023-09-27 03:24:17.279
DTC Client socket (1) | CloseSocket call. | 2023-09-27 03:24:17.280
Trading Evaluator | Disconnected. | 2023-09-27 03:24:17.280
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 03:24:17.280
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-09-27 03:24:17.280
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-09-27 03:24:17.447
DTC Client socket (1) | Closed. | 2023-09-27 03:24:17.447
Trading Evaluator | Connecting to the server tradesimulation2.sierracharts.com. Port 11096 | 2023-09-27 03:24:19.294
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-27 03:24:19.294
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-09-27 03:24:19.294
DTC Client socket (1) | Connecting to IP: 142.215.17.188. | 2023-09-27 03:24:19.294
DTC Client socket (1) | Connect event error. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2023-09-27 03:24:21.938 *
DTC Client socket (1) | CloseSocket call. | 2023-09-27 03:24:21.938
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-27 03:24:21.938
DTC Client socket (1) | Closed. | 2023-09-27 03:24:21.938
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 03:24:21.938
DTC Client socket (0) | CloseSocket call. | 2023-09-27 03:24:21.954
Trading Evaluator | Disconnected. | 2023-09-27 03:24:21.954
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 03:24:21.954
Trading Evaluator | Connecting to the server tradesimulation4.sierracharts.com. Port 11096 | 2023-09-27 03:24:23.955
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-27 03:24:23.955
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-09-27 03:24:23.955
DTC Client socket (1) | Connecting to IP: 162.251.232.244. | 2023-09-27 03:24:23.955
Trading Evaluator | Network connection to server complete. | 2023-09-27 03:24:24.133
Trading Evaluator | Starting socket receive thread. | 2023-09-27 03:24:24.133
Trading Evaluator | Sending encoding request to server: Binary VLS. Compression: none | 2023-09-27 03:24:24.133
Trading Evaluator | Setting DTC encoding to Binary VLS | 2023-09-27 03:24:24.629
Trading Evaluator | Sending logon request message. | 2023-09-27 03:24:24.629
Trading Evaluator | Received logon response. | 2023-09-27 03:24:24.806
Trading Evaluator | Server Name: SC DTC Server. | 2023-09-27 03:24:24.806
Trading Evaluator | Server protocol version: 8. Client protocol version: 8 | 2023-09-27 03:24:24.806
Trading Evaluator | Logon error received from server: Secondary instance is not allowing connections to this server | 2023-09-27 03:24:24.806
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-27 03:24:24.806
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 03:24:24.806
Trading Evaluator | Waiting for socket receive thread to end | 2023-09-27 03:24:24.829
DTC Client socket (1) | CloseSocket call. | 2023-09-27 03:24:24.829
Trading Evaluator | Disconnected. | 2023-09-27 03:24:24.829
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 03:24:24.829
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-09-27 03:24:24.829
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-09-27 03:24:24.995
DTC Client socket (1) | Closed. | 2023-09-27 03:24:24.995
Trading Evaluator | Connecting to the server tradesimulation2.sierracharts.com. Port 11096 | 2023-09-27 03:24:26.839
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-27 03:24:26.840
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-09-27 03:24:26.840
DTC Client socket (1) | Connecting to IP: 142.215.17.188. | 2023-09-27 03:24:26.840
DTC Client socket (1) | Connect event error. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2023-09-27 03:24:29.517 *
DTC Client socket (1) | CloseSocket call. | 2023-09-27 03:24:29.521
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-27 03:24:29.521
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 03:24:29.521
DTC Client socket (1) | Closed. | 2023-09-27 03:24:29.521
DTC Client socket (0) | CloseSocket call. | 2023-09-27 03:24:29.545
Trading Evaluator | Disconnected. | 2023-09-27 03:24:29.545
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 03:24:29.545
Trading Evaluator | Connecting to the server tradesimulation4.sierracharts.com. Port 11096 | 2023-09-27 03:24:31.549
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-27 03:24:31.549
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-09-27 03:24:31.549
DTC Client socket (1) | Connecting to IP: 162.251.232.244. | 2023-09-27 03:24:31.549
Trading Evaluator | Network connection to server complete. | 2023-09-27 03:24:31.724
Trading Evaluator | Starting socket receive thread. | 2023-09-27 03:24:31.724
Trading Evaluator | Sending encoding request to server: Binary VLS. Compression: none | 2023-09-27 03:24:31.724
Trading Evaluator | Setting DTC encoding to Binary VLS | 2023-09-27 03:24:32.215
Trading Evaluator | Sending logon request message. | 2023-09-27 03:24:32.215
Trading Evaluator | Received logon response. | 2023-09-27 03:24:32.387
Trading Evaluator | Server Name: SC DTC Server. | 2023-09-27 03:24:32.387
Trading Evaluator | Server protocol version: 8. Client protocol version: 8 | 2023-09-27 03:24:32.387
Trading Evaluator | Logon error received from server: Secondary instance is not allowing connections to this server | 2023-09-27 03:24:32.387
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-27 03:24:32.387
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 03:24:32.387
Trading Evaluator | Waiting for socket receive thread to end | 2023-09-27 03:24:32.396
DTC Client socket (1) | CloseSocket call. | 2023-09-27 03:24:32.396
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-09-27 03:24:32.396
Trading Evaluator | Disconnected. | 2023-09-27 03:24:32.396
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 03:24:32.396
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-09-27 03:24:32.560
DTC Client socket (1) | Closed. | 2023-09-27 03:24:32.561
Trading Evaluator | Connecting to the server tradesimulation2.sierracharts.com. Port 11096 | 2023-09-27 03:24:34.410
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-27 03:24:34.460
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-09-27 03:24:34.460
DTC Client socket (1) | Connecting to IP: 142.215.17.188. | 2023-09-27 03:24:34.460
DTC Client socket (1) | Connect event error. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2023-09-27 03:24:37.135 *
DTC Client socket (1) | CloseSocket call. | 2023-09-27 03:24:37.135
DTC Client socket (1) | Closed. | 2023-09-27 03:24:37.135
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-27 03:24:37.135
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 03:24:37.135
DTC Client socket (0) | CloseSocket call. | 2023-09-27 03:24:37.147
Trading Evaluator | Disconnected. | 2023-09-27 03:24:37.147
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 03:24:37.148
Trading Evaluator | Connecting to the server tradesimulation4.sierracharts.com. Port 11096 | 2023-09-27 03:24:39.174
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-27 03:24:39.174
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-09-27 03:24:39.175
DTC Client socket (1) | Connecting to IP: 162.251.232.244. | 2023-09-27 03:24:39.175
Trading Evaluator | Network connection to server complete. | 2023-09-27 03:24:39.351
Trading Evaluator | Starting socket receive thread. | 2023-09-27 03:24:39.351
Trading Evaluator | Sending encoding request to server: Binary VLS. Compression: none | 2023-09-27 03:24:39.351
Trading Evaluator | Setting DTC encoding to Binary VLS | 2023-09-27 03:24:39.850
Trading Evaluator | Sending logon request message. | 2023-09-27 03:24:39.850
Trading Evaluator | Received logon response. | 2023-09-27 03:24:40.011
Trading Evaluator | Server Name: SC DTC Server. | 2023-09-27 03:24:40.011
Trading Evaluator | Server protocol version: 8. Client protocol version: 8 | 2023-09-27 03:24:40.011
Trading Evaluator | Logon error received from server: Secondary instance is not allowing connections to this server | 2023-09-27 03:24:40.011
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-27 03:24:40.011
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 03:24:40.011
Trading Evaluator | Waiting for socket receive thread to end | 2023-09-27 03:24:40.027
DTC Client socket (1) | CloseSocket call. | 2023-09-27 03:24:40.028
Trading Evaluator | Disconnected. | 2023-09-27 03:24:40.028
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 03:24:40.028
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-09-27 03:24:40.028
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-09-27 03:24:40.192
DTC Client socket (1) | Closed. | 2023-09-27 03:24:40.192
Trading Evaluator | Connecting to the server tradesimulation2.sierracharts.com. Port 11096 | 2023-09-27 03:24:42.023
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-27 03:24:42.023
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-09-27 03:24:42.023
DTC Client socket (1) | Connecting to IP: 142.215.17.188. | 2023-09-27 03:24:42.023
DTC Client socket (1) | Connect event error. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2023-09-27 03:24:44.699 *
DTC Client socket (1) | CloseSocket call. | 2023-09-27 03:24:44.699
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-27 03:24:44.699
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 03:24:44.699
DTC Client socket (1) | Closed. | 2023-09-27 03:24:44.699
DTC Client socket (0) | CloseSocket call. | 2023-09-27 03:24:44.713
Trading Evaluator | Disconnected. | 2023-09-27 03:24:44.713
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 03:24:44.713
Trading Evaluator | Connecting to the server tradesimulation4.sierracharts.com. Port 11096 | 2023-09-27 03:26:44.708
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-27 03:26:44.725
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-09-27 03:26:44.725
DTC Client socket (1) | Connecting to IP: 162.251.232.244. | 2023-09-27 03:26:44.726
Trading Evaluator | Network connection to server complete. | 2023-09-27 03:26:44.893
Trading Evaluator | Starting socket receive thread. | 2023-09-27 03:26:44.893
Trading Evaluator | Sending encoding request to server: Binary VLS. Compression: none | 2023-09-27 03:26:44.894
Trading Evaluator | Setting DTC encoding to Binary VLS | 2023-09-27 03:26:45.404
Trading Evaluator | Sending logon request message. | 2023-09-27 03:26:45.404
Trading Evaluator | Received logon response. | 2023-09-27 03:26:45.570
Trading Evaluator | Server Name: SC DTC Server. | 2023-09-27 03:26:45.570
Trading Evaluator | Server protocol version: 8. Client protocol version: 8 | 2023-09-27 03:26:45.570
Trading Evaluator | Logon error received from server: Secondary instance is not allowing connections to this server | 2023-09-27 03:26:45.570
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-27 03:26:45.570
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 03:26:45.570
Trading Evaluator | Waiting for socket receive thread to end | 2023-09-27 03:26:45.596
DTC Client socket (1) | CloseSocket call. | 2023-09-27 03:26:45.597
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-09-27 03:26:45.597
Trading Evaluator | Disconnected. | 2023-09-27 03:26:45.597
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 03:26:45.597
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-09-27 03:26:45.764
DTC Client socket (1) | Closed. | 2023-09-27 03:26:45.764
The message log has been sent to support. | 2023-09-27 03:26:50.852 *
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2023-09-27 03:26:50.852
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | New receive buffer size: 32768 | 2023-09-27 03:26:50.853
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 95.216.233.104. | 2023-09-27 03:26:50.853
Sending of the Message Log is completed. The response was saved to E:\SierraChart\Data\MessageLogAnalysis.htm | 2023-09-27 03:26:51.356
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | CloseSocket call. | 2023-09-27 03:26:51.626
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2023-09-27 03:26:51.626
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2023-09-27 03:26:51.689
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. | 2023-09-27 03:26:51.689
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Creating socket. Using TLS 1.2. | 2023-09-27 03:27:12.274
The message log has been sent to support. | 2023-09-27 03:27:12.274 *
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | New receive buffer size: 32768 | 2023-09-27 03:27:12.274
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Connecting to IP: 95.216.233.104. | 2023-09-27 03:27:12.274
Sending of the Message Log is completed. The response was saved to E:\SierraChart\Data\MessageLogAnalysis.htm | 2023-09-27 03:27:12.701
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | CloseSocket call. | 2023-09-27 03:27:12.968
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Shutdown started. Waiting for graceful close. | 2023-09-27 03:27:12.968
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Socket gracefully closed by remote side. | 2023-09-27 03:27:13.017
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Closed. | 2023-09-27 03:27:13.017
Saved Chartbook: AUDUSD.Cht. Time: 0.0073 seconds. | 2023-09-27 03:27:29.814
Saved Chartbook: EURUSD.Cht. Time: 0.0077 seconds. | 2023-09-27 03:27:29.823
Date Time Of Last Edit: 2023-09-27 10:24:54
[2023-09-27 08:40:19]
User499894 - Posts: 45
Same here too.
Created the DTC Protocol server. | 2023-09-27 10:33:47.188
DTC Protocol Server listening on port 11099. | 2023-09-27 10:33:47.189
Reading Internal Order ID file. | 2023-09-27 10:33:47.189
Reading Trade Orders file. | 2023-09-27 10:33:47.300
Reading Trade Positions file. | 2023-09-27 10:33:47.301
Reading Trade Account Data files. | 2023-09-27 10:33:47.301
UDPListener (1784). Port 22904 | Listening on UDP port 22904. | 2023-09-27 10:33:47.306
Software version: 2543 64-bit | 2023-09-27 10:33:47.306
Primary Thread ID: 11444 | 2023-09-27 10:33:47.306
Usage end date: 2023-10-06 | 2023-09-27 10:33:47.306
Enabled for: Advanced Features 2. | 2023-09-27 10:33:47.306
Enabled for: Sierra Chart Historical Data Service. | 2023-09-27 10:33:47.306
Enabled for: Denali Real-Time Exchange Data Feed. | 2023-09-27 10:33:47.306
Enabled for: Delayed Denali Exchange Data Feed. | 2023-09-27 10:33:47.306
Enabled for exchange2: CME (Trading Account Required) | 2023-09-27 10:33:47.306
Enabled for exchange2: CBOT (Trading Account Required) | 2023-09-27 10:33:47.306
Enabled for exchange2: COMEX (Trading Account Required) | 2023-09-27 10:33:47.306
Enabled for exchange2: NYMEX (Trading Account Required) | 2023-09-27 10:33:47.306
Enabled for exchange2: fairx_exchange.data | 2023-09-27 10:33:47.306
Enabled for exchange2: NASDAQ Global Indexes | 2023-09-27 10:33:47.306
Allow Support for Sierra Chart Data Feeds is enabled. | 2023-09-27 10:33:47.306
Current selected Data/Trading service: Trading Evaluator | 2023-09-27 10:33:47.306
Custom symbol settings values: enabled | 2023-09-27 10:33:47.306
Chart Update Interval: 1000 | 2023-09-27 10:33:47.306
Intraday Data Storage Time Unit: 0 | 2023-09-27 10:33:47.306
Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2023-09-27 10:33:47.306
2023-09-27 08:33:47 Local computer time in UTC | 2023-09-27 10:33:47.306
2023-09-27 10:33:47 Local computer time in SC Time Zone | 2023-09-27 10:33:47.306
2023-09-27 08:33:46 Server time in UTC | 2023-09-27 10:33:47.306
Local computer UTC time and Server UTC time difference: 0 seconds. | 2023-09-27 10:33:47.306
Program path: F:\SierraChart\ | 2023-09-27 10:33:47.306
Data Files path: F:\SierraChart\Data\ | 2023-09-27 10:33:47.306
OS Version Number: 10.0 | 2023-09-27 10:33:47.306
Locale Setting: C | 2023-09-27 10:33:47.306
DLLs: Convergent_64.dll, ETFISv3_64.dll, FC_S3_V3_Auto_64.dll, FC_StepMA_2151_64.dll, FC_StepMA_64.dll, FootprintReversalSystem_64.dll, MTATradingFlowIndicator_64.dll, MyTradeAssist_64.dll, OFA Bars (by Zdislav)_2151.dll, Smaug_SC_Library_64.dll, sst_AutoTradingOnSignal_64.dll, sst_FreeBundle.dll, sst_FreeBundle_2151.dll, sst_FreeBundle_2151_64.dll, sst_FreeBundle_2273_64.dll, sst_FreeBundle_64.dll, sst_renko_optimize_64.dll, SST_Signal_64.dll, TheRationalTrader.dll, TheRationalTrader_64.dll, Trade29CustomStudies_2151_64.dll | 2023-09-27 10:33:47.312
Allowed protected custom studies: FC StepMA, Smaug_SC_Library, SST_FreeBundle, TheRationalTrader, Trade29 Custom Studies, TRT-MachineLearning, zyp_app | 2023-09-27 10:33:47.312
Crash reporter started: true | 2023-09-27 10:33:47.312
Trading Evaluator | Connecting to the server tradesimulation2.sierracharts.com. Port 11096 | 2023-09-27 10:36:34.755
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-27 10:36:34.756
DTC Client socket (1) | New receive buffer size: 0 | 2023-09-27 10:36:34.756
DTC Client socket (1) | Connecting to IP: 142.215.17.188. | 2023-09-27 10:36:34.756
DTC Client socket (1) | Connect event error. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2023-09-27 10:36:36.157
DTC Client socket (1) | CloseSocket call. | 2023-09-27 10:36:36.157
Trading Evaluator | Failed connections: 49 | 2023-09-27 10:36:36.158
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-27 10:36:36.158
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 10:36:36.158
DTC Client socket (1) | Closed. | 2023-09-27 10:36:36.158
DTC Client socket (0) | CloseSocket call. | 2023-09-27 10:36:36.164
Trading Evaluator | Disconnected. | 2023-09-27 10:36:36.164
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 10:36:36.164
Trading Evaluator | Connecting to the server tradesimulation4.sierracharts.com. Port 11096 | 2023-09-27 10:36:38.164
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-27 10:36:38.164
DTC Client socket (1) | New receive buffer size: 0 | 2023-09-27 10:36:38.165
DTC Client socket (1) | Connecting to IP: 162.251.232.244. | 2023-09-27 10:36:38.165
Trading Evaluator | Network connection to server complete. | 2023-09-27 10:36:38.326
Trading Evaluator | Starting socket receive thread. | 2023-09-27 10:36:38.326
Trading Evaluator | Sending encoding request to server: Binary VLS. Compression: none | 2023-09-27 10:36:38.326
Trading Evaluator | Setting DTC encoding to Binary VLS | 2023-09-27 10:36:38.814
Trading Evaluator | Sending logon request message. | 2023-09-27 10:36:38.814
Trading Evaluator | Received logon response. | 2023-09-27 10:36:38.977
Trading Evaluator | Server Name: SC DTC Server. | 2023-09-27 10:36:38.977
Trading Evaluator | Server protocol version: 8. Client protocol version: 8 | 2023-09-27 10:36:38.977
Trading Evaluator | Logon error received from server: Secondary instance is not allowing connections to this server | 2023-09-27 10:36:38.977
Trading Evaluator | Failed connections: 50 | 2023-09-27 10:36:38.977
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-27 10:36:38.977
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 10:36:38.977
Trading Evaluator | Waiting for socket receive thread to end | 2023-09-27 10:36:38.986
DTC Client socket (1) | CloseSocket call. | 2023-09-27 10:36:38.987
Trading Evaluator | Disconnected. | 2023-09-27 10:36:38.987
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 10:36:38.987
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-09-27 10:36:38.987
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-09-27 10:36:39.150
DTC Client socket (1) | Closed. | 2023-09-27 10:36:39.150
Trading Evaluator | Connecting to the server tradesimulation2.sierracharts.com. Port 11096 | 2023-09-27 10:36:40.988
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-09-27 10:36:40.988
DTC Client socket (1) | New receive buffer size: 0 | 2023-09-27 10:36:40.988
DTC Client socket (1) | Connecting to IP: 142.215.17.188. | 2023-09-27 10:36:40.988
DTC Client socket (1) | Connect event error. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2023-09-27 10:36:42.385
DTC Client socket (1) | CloseSocket call. | 2023-09-27 10:36:42.385
Trading Evaluator | Failed connections: 51 | 2023-09-27 10:36:42.385
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-09-27 10:36:42.385
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 10:36:42.386
DTC Client socket (1) | Closed. | 2023-09-27 10:36:42.386
DTC Client socket (0) | CloseSocket call. | 2023-09-27 10:36:42.399
Trading Evaluator | Disconnected. | 2023-09-27 10:36:42.399
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-09-27 10:36:42.399
File >> Disconnect selected. | 2023-09-27 10:36:44.248
DTC Client socket (0) | CloseSocket call. | 2023-09-27 10:36:44.248
Trading Evaluator | Disconnected. | 2023-09-27 10:36:44.248
Date Time Of Last Edit: 2023-09-27 10:24:24
[2023-09-27 12:24:09]
This issue seemed to resolve itself with time (overnight).
Please close this support request.
[2023-09-27 13:33:05]
Sierra_Chart Engineering - Posts: 17190
This has been resolved and it seems to be the result of one or more users, causing a high processing load triggering secondary issues.
We are taking steps to eliminate the impact of that.
Date Time Of Last Edit: 2023-09-27 13:33:21
