Date/Time: Wed, 27 Nov 2024 03:52:38 +0000
[Programming Help] - ACSIL zigzag past peaks
View Count: 379
[2023-09-27 01:04:20] |
Devil_On_WallStreet - Posts: 67 |
For the life of me I cannot figure out the proper way to refer to values at past zigzag peaks... I've been able to get to the previous peak and the next previous, but that is all I am trying to compare and analyze values at the most recent peak with the past 2 in the same direction.... as well as the past 3 in the opposite... I feel like I am missing something real easy like [PeakIndex-4] but everything I try fails |
[2023-09-27 14:29:15] |
John - SC Support - Posts: 36309 |
You would have to do this in a Spreadsheet. Refer to the following for information on how to get the zig zag peaks: Spreadsheet Example Formulas and Usage: Return Last Two Zig Zag Reversal Values For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
