Date/Time: Tue, 26 Nov 2024 17:32:22 +0000
Which minimum service pack for Daneli: NASDAQ TotalView US AND Equities Consolidated Tape
View Count: 565
[2023-09-26 19:06:08] |
BenjFlame - Posts: 324 |
Hi, which minimum SierraChart service pack is required for Daneli feeds: NASDAQ TotalView US stock data and US Equities Consolidated Tape ?
Date Time Of Last Edit: 2023-09-26 19:16:25
[2023-09-26 20:20:46] |
John - SC Support - Posts: 36300 |
You just need to be on one of the "Integrated" packages. The lowest cost one of these is the "Integrated Standard" (Package 10). Refer to the information here: Description of Service Packages and Pricing: Integrated Packages For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-10-16 03:03:01] |
ElsonJr - Posts: 5 |
Hi does that mean if I am on one of the service pack, i will be able to receive NASDAQ TotalView US AND Equities Consolidated Tape real time data for free? Or do i still need to purchase the data for NASDAQ TotalView US AND Equities Consolidated Tape
[2023-10-16 15:29:08] |
You still need to pay the "exchange fee" for the exchanges that you activate. Being on one of the "Integrated" packages just gives you the ability to get the real-time data.
[2023-11-02 16:02:36] |
User818950 - Posts: 9 |
Hi, and this works with the _MBO suffix behind the equity name? |
[2023-11-02 18:15:23] |
Rather behind the equity symbol :)
[2023-11-02 19:22:34] |
When you have both the "U.S. Equities Consolidated Tape" and the "NASDAQ TotalView" exchanges active, then you can open a chart for a symbol that has the suffix of _MBO (such as IBM_MBO). Doing this will give you the bar data and the volumes from the Consolidated Tape exchange and the Market Depth information from the NASDAQ TotalView exchange.
