Date/Time: Wed, 27 Nov 2024 03:41:40 +0000
CFE data: NO automatic updating data
View Count: 270
[2023-09-26 18:36:27] |
SierraFan - Posts: 92 |
I receive CFE data(VXV23-CFE OR VXV23_FUT_CFE). This data isn't automatically updating. Ill have to go to chart settings and select delete and download data to get the chart to update. I have to do this twice for some reason. Is there a setting that Im overlooking? Thank You!
[2023-09-26 20:03:36] |
John - SC Support - Posts: 36309 |
Make sure you are only using one of those symbols and not both. There can be a conflict if you are using both symbols in different charts.
[2023-09-26 23:11:39] |
Ok Thanks. Im only using 1 of the symbols. Both versions of the symbol are doing the same thing and not updating. This is the message I receive(red download failed) when I first select delete/download data. 2nd time selecting delete/download data is when the chart will update data. https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=87757 |
VXV23_FUT_CFE.bmp - Attached On 2023-09-26 23:06:12 UTC - Size: 12.44 MB - 150 views Attachment Deleted. |
[2023-09-27 13:38:13] |
Sierra_Chart Engineering - Posts: 17190 |
We want you to restart Sierra Chart and let us know if you still have the issue.
[2023-09-27 14:52:58] |
Borubar - Posts: 17 |
Had the same issue. After updating Sierra Chart VXV23_FUT_CFE is working again.
[2023-09-27 15:31:36] |
Yep,That's it! Thanks again Sierra! The restart has it working again.
