Date/Time: Wed, 27 Nov 2024 02:24:55 +0000
Chartbooks to open on startup
View Count: 202
[2023-09-26 14:58:08]
User377189 - Posts: 172
I am unable to select the chartbooks i want opened on startup
I went to Global Settings > General Settings > General > Startup
[2023-09-26 16:14:22]
John - SC Support - Posts: 36309
That is the correct spot. Then select the button for "[Select Files to Open on Startup]" and you will get a new window where you can select the particular files.
Depending on what version you are on, the new window may be shrunk down in size, such that it looks like you can not do anything with it. If this is the case, then place your cursor on the bottom right corner of the window and when the cursor changes to where you can change the size of the window, then click and drag the window open further so you can see all the options.
For more information on how to set this up, refer to the following:
General Settings Window: Open Files On Startup (Global Settings >> General Settings >> General >> Startup)
