Date/Time: Wed, 27 Nov 2024 02:45:08 +0000
Teton now available with AMP?
View Count: 658
[2023-09-26 14:02:07]
User12089 - Posts: 361
Hello folks, i can NOW see SC Teton Order Routing among the market access providers supported by AMP - have you finally started working with them and are they one of your approved/confirmed brokers now?
[2023-09-26 15:51:16]
John - SC Support - Posts: 36309
Yes, you can now use our Teton Order Routing Service with AMP.
To do this, start by contacting AMP to have your account switched to the Teton Order Routing Service. Once you get confirmation from AMP that their work is done, then follow the instructions at the following link starting at Step #6:
Sierra Chart Teton Futures Order Routing: Setup Instructions
We see that you are setup to get EUREX data from us, so keep in mind that our Teton Order Routing Service only works for the CME Group. If you are also trading EUREX, then you will still need to connect to CQG in order to trade EUREX. This would require that you have two different accounts with AMP, if you want to set it up this way.
[2023-09-26 16:09:46]
hurrrayyyyy at last!
However yes i am also trading Eurex - so no Teton for Eurex yet, no? any plans?
Date Time Of Last Edit: 2023-09-26 16:10:53
[2023-09-26 16:30:35]
There are no plans to get EUREX working with our Teton Order Routing Service. We simply do not have enough customers to make it worth the time and expense.
