Date/Time: Tue, 26 Nov 2024 06:42:28 +0000
change the symbol with one click
View Count: 384
[2023-09-26 12:53:18]
User285770 - Posts: 41
I have a chartbook with 7 charts in it, is it possible to change the symbol of all of them with one click?
[2023-09-26 15:33:34]
John - SC Support - Posts: 36286
First, to change the symbol of all charts at once, you would want the charts to be linked together with the "Symbol" option. That way, when you change the symbol for one chart, it will change for all of them. Refer to the following:
Chart Settings: Linking
To change the symbol of a chart, refer to the following for the various options:
Changing the Symbol of a Chart
[2023-09-27 17:33:24]
ForgivingComputers.com - Posts: 960
If you create a Quote Board and link it and the charts by symbol, then you can do it in only one click.
Getting Quotes: Quote Board
[2023-12-20 16:00:00]
aseef - Posts: 49
I have linked my chart to the quote board, and it is working well.
The only problem is that I have symbol defined in TRADE AND CURRENT QUOTE SYMBOL (the trading on micros). How Can I change both on one click?
imageone click symbol change.png / V - Attached On 2023-12-20 15:59:06 UTC - Size: 21.47 KB - 55 views
[2023-12-20 16:40:29]
Refer to the third paragraph here:
Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu)
