Date/Time: Wed, 27 Nov 2024 02:27:40 +0000
Initial Balance study
View Count: 292
[2023-09-26 07:14:51] |
mwang'ini madenge - Posts: 2 |
Hello, I want to set up THE INITIAL BALANCE STUDY on my TPO study for the first five hours on each day. To display the PRE-CASH Session 00:00:00 to 4:59:59 as a vertical bar(I want the range). How do I achieve this? It keep showing me the high and low of each day on the TPO STUDY. |
[2023-09-26 14:59:28] |
John - SC Support - Posts: 36309 |
The TPO study itself has this ability. If the first five hours matches up with the TPO start, then set the input for "Initial Balance Range" to a value of "10" assuming that you are using 30 minute periods. Refer to the following: Time Price Opportunity (TPO) Profile Charts: Initial Balance Range Otherwise, there is not a way to get the Initial Balance to display as a vertical bar on the TPO chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
