Date/Time: Wed, 27 Nov 2024 03:50:35 +0000
# Clicking on studies from a chart
View Count: 241
[2023-09-25 22:53:56] |
User478380 - Posts: 184 |
Is it possible to click on a study on a chart and bring up the settings for that study? i have tried to do this but its not working. Thanks
[2023-09-26 03:23:24] |
ForgivingComputers.com - Posts: 960 |
F6 opens the Chart Studies Window. Double-Clicking a Study opens the Study Settings Window for each study. You can also click on the Settings button, once you select a study.
[2023-09-26 09:50:02] |
F6 is already assigned to another tool. How do I assign a function key to open the studies window please ?
[2023-09-26 10:05:10] |
Ignore my previous note - issue resolved.
[2023-09-27 00:18:10] |
Sierra_Chart Engineering - Posts: 17190 |
Refer to: Chart Studies: Quick Access to Study Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
