Date/Time: Wed, 27 Nov 2024 02:43:17 +0000
Changing font type in Studies separately from whole chart?
View Count: 284
[2023-09-25 18:02:48]
mojsterr - Posts: 26
Hello.
Is it possible to add the option to change font types in studies? At the moment we can only change the font type in the whole chart we are looking at, but this makes some things weird.
I want to change a font in numbers bars, so the numbers are most visible to me. Some fonts are better, some are worse. But when I change it, it also changes all the other fonts on the chart to the same one.
The default font on the charts is ok, but for numbers bars I need something that stands out more to me, but I want it to have it only in the bars and nowhere else.
Is that possible?
The other question I have is: Can we somehow make the bid and ask volume spacing in the Numbers Bars spacing smaller?
I would like to fit as much data on the charts, but while compressing the bars makes the numbers go out of the edges of the bars, while there is still some space in the middle that could be utilized.
Thank you.
Date Time Of Last Edit: 2023-09-25 18:03:59
[2023-09-25 19:22:56]
John - SC Support - Posts: 36309
There is not an option to have a different font for the Numbers Bars (or for studies in general) from the main Chart Font.
With regards to the spacing of the Bid and Ask, there are a few options in the Numbers Bars Input for "Numbers Separator Character". The one that is going to give the smallest spacing is the Vertical Line '|'.
[2023-09-25 19:45:17]
Alright, thank you.
