Date/Time: Sun, 12 Jan 2025 09:58:17 +0000
Symbols not available under: File > Find Symbol ?
View Count: 2200
[2014-07-16 14:45:45] |
User59863 - Posts: 36 |
Not available under: File > Find Symbol Need symbols for: TOPX (Topix index at TSEJ) GBPSEK GBPNOK GBPCNH GBPDKK GBPMXN GBPNOK GBPSEK EURCNH EURCZK EURDKK EURHUF EURNOK EURPLN EURRUB USDHKD USDCNH USDCZK USDDKK USDHUF USDNOK USDPLN USDRUB |
[2014-07-16 17:22:49] |
What exchange is TSEJ?
[2014-07-16 20:04:34] |
Tokyo Stock Exchange (TSEJ) All symbols @ Interactive Brokers |
[2014-07-17 08:06:13] |
Please give us until the end of the day to get all of these symbols added.
[2014-07-18 06:04:42] |
We have this symbol added: TOPX (Topix index at TSEJ) To get the symbol, restart Sierra Chart. You will find it under File >> Find Symbol. The Forex symbols will be added later today. Thank you for your patience. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-07-19 00:08:21] |
All of the Forex symbols have now been added. Restart Sierra Chart to get them. You will see them in File >> Find Symbol. Also, whether or not you see a symbol listed in Sierra Chart does not prevent you from using it. You can always manually type it into the Find Symbol >> Selected Symbol box. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-19 00:08:36
[2014-07-22 20:31:55] |
Using InteractiveBrokers Also missing following (futures) symbols/contracts in: File > Find Symbol - CT (Cotton, NYBOT) - MIR (India Rupee/USD, CME) - BRE (Brazil Real/USD, CME) - KRW (Korea Won/USD, CME) - CNY (China Yuan/USD, CME) |
[2014-07-22 22:05:08] |
We have added cotton. Restart Sierra Chart to get the new symbol. We can add the Brazilian Real, but these others are kind of pointless because they are not actively traded on the CME: - MIR (India Rupee/USD, CME) - KRW (Korea Won/USD, CME) - CNY (China Yuan/USD, CME) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-24 20:32:00
[2014-07-24 20:15:14] |
Using InteractiveBrokers Also missing following (futures) symbols/contracts in: File > Find Symbol - XINA50 (FTSE/Xinhua China A50, Singapore Exchange, sgx.com) - CES120 (CES China 120 Index, HK futures exchange, hkex.com.hk) - HHI.HK (Hang Seng China Enterprise Index, HK futures exchange, hkex.com.hk) Date Time Of Last Edit: 2014-07-26 20:01:38
[2014-07-26 20:02:46] |
Sierra, are you working to install the symbols in the previous post? |
[2014-07-26 20:05:17] |
We have started to add these, but we had a few details to finish with them. They will be ready on Monday.
[2014-07-29 04:03:45] |
These have now been added along with the Brazilian Real futures: - XINA50 (FTSE/Xinhua China A50, Singapore Exchange, sgx.com) - CES120 (CES China 120 Index, HK futures exchange, hkex.com.hk) - HHI.HK (Hang Seng China Enterprise Index, HK futures exchange, hkex.com.hk) Restart Sierra Chart and then you will see them in File >> Find Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-10 16:34:14] |
User57562 - Posts: 98 |
How about more CME Group symbols for USA contracts, such as petrochemicals, electricity, plastics, aluminum, ferrous scrap? Perhaps I am suggesting more industrial added to agri, currencies, fuels, indexes, etc. Do you have acceptance criteria on trade volume or similar? Date Time Of Last Edit: 2014-08-10 16:40:37
[2014-08-10 19:48:49] |
These will not be added since they are never requested. There is an extensive amount of work to add a symbol for an external data or trading service because all of the details about the symbol have to be looked up and verified. You are free to add your own symbols and you do not have to add them to the Global Symbol Settings. You are free to manually type in any symbol that you want. You just simply enter the symbol through File >> Find Symbol >> Selected Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-10 21:59:01] |
In regards to post #13, what Data or Trading service are using Sierra Chart with? Interactive Brokers?
[2017-02-12 00:14:49] |
cmb999 - Posts: 211 |
Re: post #12 i have HKFE entitlement for sierra chart feed, but only see HSI / MHI. can we add HHI ? . . thanks |
[2017-02-12 00:31:43] |
Yes we can set this up. Can you provide us the full descriptive name of this.
[2017-02-12 00:51:52] |
http://www.hkex.com.hk/eng/prod/drprod/hshares/hhifut.htm i think it is virtually identical to HSI, just a different index |
[2017-02-12 01:17:50] |
This is already available: Description: H-shares Index Symbol: HA?## Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-12 01:33:55] |
hmm . . i see the other hkfe symbols . .
Screen Shot 2017-02-11 at 8.30.34 PM crop.png / V - Attached On 2017-02-12 01:33:20 UTC - Size: 209.69 KB - 269 views Attachment Deleted. |
[2017-02-12 09:07:56] |
This has now been added for CQG. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-12 13:43:35] |
while we are on the subject of contracts, i do not see the substantial Kansas city wheat market on globex, http://www.cmegroup.com/trading/agricultural/grain-and-oilseed/kc-wheat_contract_specifications.html
[2017-02-12 19:24:24] |
also, i believe ICE Euribor series are listed incorrectly. you have them as serial months out to Apr 2018, when it really should be a quarterly series like eurodollar. e.g. nearest six serial months, then quarterly after, https://www.theice.com/products/38527986/Three-Month-Euribor-Futures/data
[2017-02-13 10:14:58] |
KC HRW Wheat Futures (KE) - CBOT has been added for CQG.
[2017-02-13 10:15:31] |
This is why all contract months are listed.
