Date/Time: Wed, 27 Nov 2024 02:36:26 +0000
Bug with Save Main Window to File
View Count: 214
[2023-09-25 13:30:19]
User247273 - Posts: 37
I am running version 2550 (rev.47628).
In General Settings, I have changed the "Chart Image Folder" setting to D:\Trader\Pictures\Sierra Chart\
Everything works properly when I use the "Save Chart to File" command. However, when I use the "Save Main Window to File" command, Sierra throws the following error:
Error saving the image file: D:\Trader\Pictures\Sierra_Chart\Sierra_Chart_MainWindow_2023-09-25__07_44_26.363.png | 2023-09-25 07:44:28.452
For some reason, Sierra is replacing the space in the path name between "Sierra" and "Chart" with an underscore when it tries to save the main window image.
Since "Save Chart to File" works as expected, I ran that and was able to confirm via the message log that there is no substitution of an underscore in the path name when running that command.
Date Time Of Last Edit: 2023-09-25 13:30:49
[2023-09-25 13:59:19]
Sierra_Chart Engineering - Posts: 17190
We will look into this.
