Date/Time: Wed, 27 Nov 2024 01:33:42 +0000
Time-Axis date-format→yyy-MM-dd.
View Count: 386
[2023-09-24 18:08:27] |
User408639 - Posts: 69 |
Moin Moin. Do Yoe guys/gals know, where to set the date-format in SC. Right now it is month-day. It always takes a bit of time to readjust myself from year-month-day. Googling quite a lot did not show a thing for this (Maybe I did it wrong). "Change Date Format " said, that it does not work, but it not say, for which screen-element. Right now, I am assuming, that a simple-format-change like this must be configurable-somewhere. Cheers, Michael. Date Time Of Last Edit: 2023-09-24 18:09:32
[2023-09-24 22:03:30] |
Sierra_Chart Engineering - Posts: 17189 |
So we can understand the chart you are looking at, post an image: Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-10-02 14:20:13] |
Moin Moin. Within the uploaded image, then MM-dd"-Dates have been encircled in gree. I would be liking to configure them to yyyy-MM-dd hh:mm:ss . Is that possible. _Tschüß, __Michael. P.S.: Hopefully You can see the screenshot. |
Time-Format TPO-chart.png / V - Attached On 2023-10-02 14:17:31 UTC - Size: 38.84 KB - 83 views Attachment Deleted. |
[2023-10-02 14:25:26] |
Yes we can do this. We will add an option for this. We have to look into this more carefully to check specific implementation details.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-10-02 14:25:39
