Date/Time: Wed, 27 Nov 2024 02:38:18 +0000
interactive internals
View Count: 916
[2014-07-16 14:39:55] |
User53196 - Posts: 13 |
Cannot get ticks and other internals to display properly. they show up but just as flat lines. what to do?
[2014-07-16 17:48:14] |
Tell us one of the market statistics symbols you are using.
[2014-07-16 21:03:31] |
I am with interactive brokers,,, symbols that don't work are tick-nyse adr-sp adv-nyse |
[2014-07-17 01:14:24] |
Open a chart for the TICK-NYSE symbol. Check the Session Times settings for the chart to make sure they cover the full 24-hour span in case there is some time zone issue. Here are the instructions: https://www.sierrachart.com/index.php?page=doc/helpdetails3.html#h3.3 If there still is a problem, post an image of the chart, by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-17 08:07:22
