Date/Time: Wed, 27 Nov 2024 02:40:04 +0000
Change running order with Breakeven for stop possible?
View Count: 278
[2023-09-23 20:36:25] |
User299985 - Posts: 6 |
Hi all, lets assume I have an order placed and running with 1 target and 1 stop. Stop has move to breakeven for stop acitivated, with type Offset in Ticks Triggered, BE level offset 0, Trigger Offset 40. Is it possible to change the characteristics of the stop, like the trigger offset? Regards Christian |
[2023-09-25 15:31:05] |
John - SC Support - Posts: 36309 |
It is not possible to change the characteristics of the Stop once you have an order placed. You would have to cancel that Stop order and then submit a new one using the "Send Attached Orders Position/Price" Trade Order Type (in order to have it show as part of the same OCO). Refer to the following: Order Types: Send Attached Orders - Position/Price For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-09-25 18:22:58] |
very good, thank you!
