Date/Time: Thu, 10 Sep 2026 20:13:44 +0000
Text/CSV Data Format
View Count: 1292
[2014-07-16 14:03:24]
lou_diamonds - Posts: 39
I'm trying to import data for a historical chart with no open data. How do I get it to import correctly?
The data I have is Date, High, Low, Close, Volume. Currently, the system automatically tries to assign the high data as the open, since it is the 1st column after the date. Even though I have the headers, it doesn't import properly.
[2014-07-16 15:28:21]
Ok. I just figured it out for anyone else dealilng with this. If you put 0 for the Open, it will omit the Open, even if you have OHLC bars set.
Thanks!
