Date/Time: Wed, 27 Nov 2024 02:41:08 +0000
Copy Chart Drawings
View Count: 968
[2014-07-16 13:51:20] |
sonyclan1 - Posts: 7 |
Have you any plans in the future to give more versatility to the 'Copy Chart Drawings From Chart #'s', feature. It would be good if the feature was within the Drawing Properties and one could choose which drawing could be copied to which charts. At the moment all drawings are copied which can lead to information not required on other charts. Date Time Of Last Edit: 2014-07-16 13:52:49
[2014-07-16 17:16:31] |
This is not planned.
[2014-07-16 19:30:03] |
It would be an incredible enhancement to an already brilliant Charting Software. Please consider it. |
[2014-07-16 23:28:59] |
We will look into this, but in order to do this efficiently it does require a lot of special programming. If it is done in a simple and straightforward way, it would be inefficient.
