Date/Time: Fri, 22 Nov 2024 07:55:41 +0000
B/A depthbars
View Count: 1821
[2013-05-03 15:46:19]
SgtJ - Posts: 154
v969 still not working correctly re the "number of bid/ask records".
originally reported here
http://www.sierrachart.com/supportboard/showthread.php?t=37608
v969 is doing exactly what v959 did. Near the 800-900 level it starts subtracting values.
[2013-05-03 16:35:24]
What do you have the Number of Stored Time and Sales Records set to?
If it is set high enough, then we do not know the problem with this is and we cannot cannot spend time on it.
The best we can do is convert the study to ACSIL and you can have a look or just create your own.
[2013-05-07 16:10:02]
SgtJ - Posts: 154
Significantly bumping up the stored records seems to have corrected the issue. ty
[2013-05-08 02:34:32]
This is good and makes sense.
