Date/Time: Wed, 27 Nov 2024 02:31:38 +0000
Sierra Chart 1 Box Reversal
View Count: 375
[2023-09-22 03:22:20] |
NomadTrader0 - Posts: 12 |
Hello I am looking to set my P&F chart , If I were to use IntraDay Chart Bar period, I dont have the option to Disable 1 Box Reversal, if you run P&F on MESZ23 with 100-3 you will see quite a few 1 box reversal. I loaded P&F study on top my P&F Chart , I do have the option to Disable 1 Box Reversal but It stooped show me current price instead It show me last X/O closing price not the realtime Price movement. Do you have any fix for this. |
[2023-09-22 14:48:04] |
John - SC Support - Posts: 36309 |
Can you please give us an image of what you are seeing by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-09-22 15:00:09] |
Hello John Please see attach screen shot for 100-3 PF Chart. Its VOl Adjusted Continue Contract MESZ23. IntraDay - 1000 days to load. |
Screenshot 2023-09-22 095719.png / V - Attached On 2023-09-22 14:58:58 UTC - Size: 27.15 KB - 71 views |
[2023-09-22 15:48:24] |
The reason that is occurring is because you are using such a large tick range along with the option for "New Bar at Session Start" set to "Yes". If you set "New Bar at Session Start" to "No", then it will show as you expect. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-09-22 15:55:36] |
I am not using PF study, this chart is from IntraDay Bar Settings. I dont see an option to change New Bar at Session.
[2023-09-22 16:56:42] |
Refer to the following: Chart Settings: New Bar at Session Start (Chart >> Chart Settings >> Session Times >> Intraday Chart Session Times menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-09-22 18:22:50] |
thank you , charts are much better now.
