Date/Time: Wed, 27 Nov 2024 02:38:57 +0000
DOM Quantity Looks Small
View Count: 297
[2023-09-22 03:19:03] |
User478349 - Posts: 5 |
The numbers on my DOM look quite small. For example, I am expecting say 125 at 14890.25, however, it only shows 1. It is almost as if there is a Volume Display Multiplier like in the Numbers Bar Settings set to be really low (like 0.1 or 0.001) for my DOM. How can I make the quantity look bigger for my DOM? Thanks! |
[2023-09-22 14:40:26] |
John - SC Support - Posts: 36309 |
We need to see an image of what you are seeing. Please follow the instructions at the following link to get us an image: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-09-22 20:22:46] |
Please see below link: https://www.sierrachart.com/image.php?Image=1695414055771.png My expectation is that the recent traded bid/ask as well as the bid/ask size columns would have larger numbers like 100, 158, 260 etc instead of just showing 5, 8, 9 etc. This is for NQ futures. Thanks again. |
[2023-09-22 20:47:47] |
What you are seeing are the values that we get from the exchange. They are correct.
