Date/Time: Wed, 27 Nov 2024 03:32:41 +0000
dom volume profile
View Count: 451
[2023-09-21 20:59:52] |
Gtrader510 - Posts: 72 |
hi please help with dom volume profile time reset i want it to reset at market close which is 1pm pacific time and then show overnight profile until morning which is 6:30am pacific it should reset it again. i tried playing with the setting but can't figure it out yet.im attaching pic
2023-09-21 13_58_51-.png / V - Attached On 2023-09-21 20:59:15 UTC - Size: 274.81 KB - 249 views |
[2023-09-21 21:01:53] |
here is the time setting and vp setting
Attachment Deleted. 2023-09-21 14_00_11-Chart Settings _ ESZ23_FUT_CME_MESZ23_FU.png / V - Attached On 2023-09-21 21:01:23 UTC - Size: 26.32 KB - 96 views 2023-09-21 14_00_59-Study Settings_ VBP - Session Start Time.png / V - Attached On 2023-09-21 21:01:30 UTC - Size: 50.42 KB - 79 views |
[2023-09-21 21:21:36] |
John - SC Support - Posts: 36309 |
Please change the following inputs and see if this works for what you want: - Volume Graph Period Type: Trading Day Start Time to End - Reset at Day Session - Exclude Evening Session Profiles Except for Last Day: No Otherwise, keep the other Inputs as they are (particularly "Use Separate Profile for Evening Session", which needs to be "Yes"). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-09-21 21:49:23] |
i tried the first solution but still it's same did not change anything
[2023-09-22 14:20:33] |
So it did not reset at one of the session start times? If so, which time did it not reset (Evening Session or Day Session)?
