Date/Time: Wed, 27 Nov 2024 02:36:57 +0000
No Data for SPZ23
View Count: 605
[2023-09-21 19:31:17]
NomadTrader0 - Posts: 12
Hello
I am trying to pull SPZ23 on to my chart and its coming up blank. Can you please see if there is an issue with the data or I am missing something on my software.
[2023-09-21 20:16:41]
John - SC Support - Posts: 36309
If you are looking for the full sized S&P 500 Index, that product was deprecated several years ago. The SP symbol now represents the "Singapore Naphtha (Platts) Futures". Which, interestingly, does not see any trading. You can see this at the CME Group website:
https://www.cmegroup.com/markets/energy/refined-products/singapore-naphtha-swap-futures.quotes.html#venue=globex
[2023-09-21 21:25:07]
Singapore Naphtha is ASPZ3 , I am looking for SPZ23.
Is there a way I can see full contract data , or CME Floor data. I know CQG supports symbol SP.
[2023-09-21 21:29:15]
Sorry, you are right, the Globex for Singapore Naptha is ASP, we were looking at the Clearing.
Still, the Full Size SP is no longer available. Refer to the following:
https://www.cmegroup.com/education/articles-and-reports/faq-conclusion-of-standard-sp-500-futures-and-options-trading.html
[2023-09-21 21:35:10]
Do you know how CQG Is generating data for this symbol. I have asked them once they told me its part of Professional Package which ofcource cost more, I will pay for it if its available.
Please see attach screenshot.
imageScreenshot 2023-09-21 163405.png / V - Attached On 2023-09-21 21:34:51 UTC - Size: 265.18 KB - 80 views
[2023-09-22 14:18:49]
Searching the CQG symbol information for SP gives the following result:
https://www.cqg.com/partners/exchanges/tradable-symbols?search_api_views_fulltext=SP
[2023-09-22 16:45:39]
User584084 - Posts: 262
Try EPZ23.
https://www.cqg.com/partners/exchanges/tradable-symbols?search_api_views_fulltext=EP&f%5B0%5D=field_tradable_symbols_instrumen%3AFuture
Date Time Of Last Edit: 2023-09-22 16:46:16
[2023-09-22 18:35:14]
Can not find EPZ23 in SC, only ESZ23.
[2023-09-22 18:40:45]
If you are connected to CQG, the symbol would be F.US.EPZ23. Otherwise, if you are connected to any other service, the symbol will be ES (of some sort, all services use a different symbology - for instance with SC Data - All Services, the symbol will be ESZ23-CME).
[2023-09-22 18:44:59]
ESZ23 in SC would be equivalent to EPZ23 in CQG. ESZ23 is the E-Mini S&P 500 Dec 2023 (Z) Futures Contract, $50 per point. MESZ23 is the Micro E-Mini S&P 500 Dec 2023 (Z) Futures Contract, $5 per point.
Date Time Of Last Edit: 2023-09-22 18:46:03
[2023-09-22 18:45:12]
I have change the Intraday session timings to CME RTH, it will be as close to "SP" as I can get.
