Date/Time: Wed, 27 Nov 2024 03:40:44 +0000
Footprint,Bid/Ask volume chart
View Count: 455
[2023-09-21 17:14:49]
Jimmyz83 - Posts: 52
The chart shows green up (buyers) and red down (sellers), the bottom shows the cumulative delta for the period. Normally the positive (green) delta is always green when positive. Lately I have seen the color still be green as in more buyers than sellers, but the number in the green bottom is a negative number. Can you help with why that is. Or what the meaning is for this scenario?
Screen shot is attached.
Thanks for the help,
imageScreenshot 2023-09-21 085130.jpg / V - Attached On 2023-09-21 17:14:12 UTC - Size: 31.27 KB - 123 views
[2023-09-21 17:32:10]
John - SC Support - Posts: 36309
For the Numbers Bars Calculated Values, do you have the Input for "Color Background Based on Value Percentage" set to "Yes" or "No"?
If "Yes", then are your "Range x Down Color(s)" green colorings or some other color (if so, what color)?
Also, exactly which subgraph are you displaying from the study?
[2023-09-21 17:48:16]
Number Bars study:
Background coloring method - Based on separate ask volume bid volume - actual
All up ranges are green, all down ranges are red.
Number Bars cumulative delta study:
set to Yes and all up are green and all down are red.
2 attached pics of settings. 1 for each.
Does this help explain?
tks
imageNumber bars.jpg / V - Attached On 2023-09-21 17:47:53 UTC - Size: 166.49 KB - 82 views
imagenumber bars cumulative delta.jpg / V - Attached On 2023-09-21 17:48:00 UTC - Size: 136.81 KB - 102 views
[2023-09-21 18:00:21]
In the Numbers Bars Calculated Values study, if you have a negative value and it is green, when the bar closes (i.e. a new bar starts) does the color stay green or does it change to red?
If so, then this is explained in the fifth paragraph of the following section:
Numbers Bars: Calculated Values Background Coloring Logic
Otherwise, we would need to get a copy of that chart to see if we can reproduce what you are seeing. To get us a chartbook with the chart, follow these instructions:
