Date/Time: Wed, 27 Nov 2024 03:36:22 +0000
Volume study for number of contracts
View Count: 253
[2023-09-21 16:51:08] |
nwills - Posts: 16 |
I am using a Tick/Volume chart set to 4000. Which volume study would show the number of contracts traded per candle? In my case each candle shows 4000 trades but I would like a number of contracts volume bar study in addition. |
[2023-09-21 17:21:40] |
John - SC Support - Posts: 36309 |
The standard "Volume" study will give you the volume per bar. Refer to the following: Volume For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
