Date/Time: Wed, 27 Nov 2024 03:51:38 +0000
Tick Data
View Count: 263
[2023-09-21 16:15:20] |
NomadTrader0 - Posts: 12 |
Hello I have a paid funded account with Dorman and I am looking to get back to Sierra chart. I have couple of questions: Is there a way I can get CME Floor traded data or PIT session and or set session hours for example 8:30 am to 3:15 pm. What is the duration of Historic CME Futures (ES, NQ etc) tick data I can get. I will be running Point and figure chart using 1 tick , so historic tick data is important specially for box size up to 50x3 or 200x3. what are the future continuation setting, do we go by following standards or we have something different. Standard Displays a chart for the lead month contract through expiration and then displays the chart for the next available contract month. Example: Using the Mar, Jun, Sep, and Dec cycle as an example, if you selected Standard-rollover at expiration, the chart would display data from the Mar contract through expiration and then continue with the Jun, displaying it through the June expiration, and so on for the Sep, and Dec contracts. Colored identification bars appear at the bottom of Daily continuation charts, to indicate a transition between contracts. Active This option sets the chart to display data for the most active contract month. Once the transition occurs between the near-term month and the next month, the further out month remains the active contract until a contract other than that becomes more active. Colored horizontal bars appear at the bottom of the continuation charts, directly above the time scale, to indicate a transition to a new contract. Additionally, you can choose to equalize the closes by selecting Equalize Closes in the Rollover Adjustments section. This equalization is done by adding the difference between the old lead month and the new lead month to the historical data. |
[2023-09-21 16:41:46] |
John - SC Support - Posts: 36309 |
Yes, refer to the Session Times information at the following link: Chart Session Times What is the duration of Historic CME Futures (ES, NQ etc) tick data I can get. I will be running Point and figure chart using 1 tick , so historic tick data is important specially for box size up to 50x3 or 200x3.
Refer to the following for how far back we have data for various exchanges: Sierra Chart Historical Data Service: What is Included what are the future continuation setting, do we go by following standards or we have something different.
Both methods are available. Refer to the information on Continuous Futures Contracts at the following link: Continuous Futures Contract Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
