Date/Time: Wed, 27 Nov 2024 00:26:10 +0000
Quote Board Graphics Setting for Alert Trigger
View Count: 469
[2023-09-21 10:00:58] |
User417302 - Posts: 67 |
I was trying to figure out how to have a symbol highlight when an alert has triggered? I have the sound setting correct, but I can't figure out how to have the symbol highlight in a color so I know which alert went off for which symbol? Thanks, |
[2023-09-22 00:10:00] |
Sierra_Chart Engineering - Posts: 17187 |
We will check on this.
[2023-09-25 18:22:09] |
How exactly did you set the alert? There may not be highlighting for the way that you did this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-09-25 18:22:40
[2023-09-25 18:27:40] |
I right clicked on the quoteboard and then clicked on “add symbol alert”.
[2023-10-06 01:42:40] |
Any update on this?
[2023-10-06 17:31:32] |
There is no highlighting supported on the Quote Board for that type of alert.
[2023-10-06 17:43:44] |
Is there any type of alert style that will allow for this?
