Date/Time: Tue, 26 Nov 2024 19:47:41 +0000
Question
View Count: 332
[2023-09-20 21:17:02]
User755165 - Posts: 9
Hello, I have activated Integrated Advanced services for a month, all graphs appear correctly but the price and graph is not moving.
Can you please advise what might be the problem?
Thank you.
Michal
[2023-09-21 10:03:53]
Sierra_Chart Engineering - Posts: 17182
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
[2023-10-24 18:17:41]
Hello, I am not able to place order in Sierra chart for my live account. Once I place the order to SCH platform Trade simulation mode automatically switches to "on" so all trades are only as "demo".
Can you please advice?
Thanks.
Michal
[2023-10-24 20:57:15]
John - SC Support - Posts: 36304
User755165:
This means that your Data/Trade Service Settings are not setup to connect to your live trading account.
What order routing service or broker do you use for your live account?
[2023-10-25 06:40:17]
Hello, I am using AMP futures.
Thank you.
Michal
[2023-10-25 14:37:26]
AMP could have you setup for order routing with either CQG or our own Teton Order Routing Service.
If you are setup with CQG, then follow the Setup Instructions at the following link:
CQG Trading Platform Service: Setup Instructions
If you are setup with our Teton Order Routing Service, then follow the Setup Instruction at the following link starting at Step #6:
Sierra Chart Teton Futures Order Routing: Setup Instructions
