Date/Time: Wed, 27 Nov 2024 02:22:06 +0000
Text only appearing when I click on a bar
View Count: 916
[2014-07-16 11:53:38] |
lou_diamonds - Posts: 39 |
Is there a way to make Text only appearing when I hover over a bar or click on a bar? I want to comment on each bar in a series of 40 bars, but if I just use the Type Text tool, it gets very jumbled up. So, I'm looking make it much more clean, by allowing the comments to display only I click on them. |
[2014-07-16 18:49:49] |
We understand what you are looking for and this is not supported.
[2014-07-16 21:36:42] |
Is there a way to request this? It would make for a nice feature to have comment bubbles for those of us who want to follow a stock bar-by-bar. It would definitely be a great feature for Sierra Chart.
[2014-07-18 07:39:17] |
This is highly unlikely to be added.
