Date/Time: Wed, 27 Nov 2024 03:36:59 +0000
[Programming Help] - lost files
View Count: 243
[2023-09-20 20:27:35]
User671813 - Posts: 2
my second computer (laptop I travel with) has lost all it's trade setup files how can I get them back
[2023-09-20 20:56:02]
John - SC Support - Posts: 36309
You can look and see if they are available in the Backups folder under the main Sierra Chart installation folder. The Trade Configuration files that you select on the Trading Window, have an extension of .twconfig. You would need to move these from the Backups folder to the Data folder and remove the number in the front.
If you are looking for something else, you would do the same thing, just with a different extension depending on the file you are looking for. Refer to the following that gives information on the files at step #5:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
Depending on your setup, you could also get the files from the other computer, if you have them there.
