Date/Time: Wed, 27 Nov 2024 03:44:11 +0000
60min vs daily historical chart
View Count: 201
[2023-09-20 19:04:27]
User562957 - Posts: 58
can you explain me why I can go back in the 60min chart 4380 days and in the daily chart only 1200 days ? When I go in the 60min chart and choose the daily I can see 4380 days. But can you tell me what is wrong with the daily chart, which setting I got wrong ?
[2023-09-20 20:22:08]
John - SC Support - Posts: 36309
We are not really understanding this.
When you change a chart to be a Daily Historical chart, the default for the number of days to load is 4380. This is also true if you start a new chart as a Daily Historical. But the actual number of days that load will depend on the symbol and how many days are actually available.
The typical default for an Intraday chart is 30 days to load. So even though you may see the numbers showing for a Daily and Intraday at the same time, only one is applying to that particular chart, the other one is "grayed out" and not editable.
