Date/Time: Wed, 27 Nov 2024 03:45:00 +0000
Data Error in TETON CME ROUTING - Dorman
View Count: 286
[2023-09-20 16:53:06]
User344477 - Posts: 4
Dear Team,
I have added Teton CME routing data feed and shows an error in downloading complete data. i tried approaching Stage 5 but even they were not able to figure this out.
When i change to SC all data feed, then charts works perfectly, but when i change to Teton CME routhing then i can only see 2 blocks on footprint chart.
I have tried delete all data and download again but same thing.
I have attached 2 screenshots.
imageSierra SC All Data okay.jpg / V - Attached On 2023-09-20 16:49:34 UTC - Size: 105.51 KB - 76 views
imageSierra Teton 1 Error.jpg / V - Attached On 2023-09-20 16:49:40 UTC - Size: 80.86 KB - 64 views
[2023-09-20 17:54:32]
John - SC Support - Posts: 36309
When connected to the Teton Order Routing Service, follow the instructions at the following link for that chart:
Be sure to select all of the contracts to redownload the data (depending on how much data you have loaded, this could take some time).
[2023-09-21 04:14:41]
Hi John,
This worked so well.. thanks a lot.
I have another question, there is one data feed called ATC Data feed. How to have the trial for that?
[2023-09-21 14:08:59]
We do not have any exchange named "ATC", nor are we familiar with this. Can you give us more information.
