Date/Time: Wed, 27 Nov 2024 04:44:48 +0000
TPO - merge profiles
View Count: 259
[2023-09-20 12:36:02]
Boris Libman - Posts: 58
on TPO charts when trying to merge profiles from multiple sessions, is there a way to do this through settings where you can indicate start of merge - end of merge, etc. rather than manually right clicking on the chart and merge right/left and having to do that manually if for each session if you're trying to merge multiple (more than 2) sessions?
[2023-09-20 15:55:09]
John - SC Support - Posts: 36309
There is not a way to define the merge. The only options are with the pointer.
