Date/Time: Wed, 27 Nov 2024 04:29:03 +0000
opening after softweare update
View Count: 223
[2023-09-20 11:51:49] |
KyleK - Posts: 28 |
After updating to new software version Sierra chart will not open. No error message and softw3are shuts down.
[2023-09-20 13:13:54] |
Sierra_Chart Engineering - Posts: 17190 |
Are you able to see the Sierra Chart Login Window? If so, then the first thing we want you to do, is run Sierra Chart in Safe Mode: Sierra Chart - Software Login Instructions: Using Safe Mode If you are still having the problem let us know and we can give you a call to look into the issue. Make sure your current telephone number is set here: https://www.sierrachart.com/UserControlPanel.php?page=ManageAccountInfo Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
