Date/Time: Wed, 27 Nov 2024 04:52:30 +0000
hi- how do I change my broker from iron beam to Amp futures within sierra charts
View Count: 338
[2023-09-20 06:07:04] |
User653513 - Posts: 11 |
-While still using Teton order routing.
[2023-09-20 15:25:52] |
John - SC Support - Posts: 36309 |
You change the "Clearing Firm" entry in the "Data/Trade Service Settings" page. If you have multiple accounts, then we recommend using two different installations of Sierra Chart, so you can always have access to both accounts. Refer to the instructions for how to install another Sierra Chart at the following link: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
