Date/Time: Wed, 27 Nov 2024 03:33:18 +0000
Rectangles
View Count: 254
[2023-09-20 03:30:19]
nicktrader - Posts: 711
I work a lot with rectangles and a lot only with the outlines. To use the crosshairs, you always have to make sure that you start outside the "box". Or if you want to create an ellipse inside the "box", there are always slight "handling conflicts".
Is it possible to "neutralize" the fill area so that only the outlines can be marked? It would be a great help.
Thanks a lot
[2023-09-20 15:24:16]
John - SC Support - Posts: 36309
We think what you are looking for is the following setting:
Chart Drawing Tools: Support Interior Rectangle Selection (Global Settings >> Tool Settings >> General >> Tool Options)
[2023-09-21 03:24:32]
Many thanks John. This is what I was looking for.
