Date/Time: Wed, 27 Nov 2024 04:45:21 +0000
SC update blanked out J cell formulas
View Count: 250
[2023-09-19 23:21:17]
sgne - Posts: 105
Just updated SC to build 2549. I had a spreadsheet for trading running. The update deleted formulas I had in cells J22 to J29. Also in other J cells, like J71 to J74. It also blanked out I and J cells at the bottom down to I124/J124. It also eliminated formatting I had in various J cells. I don't remember that happening before, but maybe I just got lucky and avoided it before by doing the update without a spreadsheet up and running when I started the update.
[2023-09-20 00:27:34]
Sawtooth - Posts: 4120
Go to the spreadsheet study settings and set 'Use Column I and J Values Version 2' to No.
(It is third from the bottom in the list.)
This is a new 'feature' that reorganizes the studies' output cells.
But I suspect this 'upgrade' will cause way more confusion than it was intended to eliminate.
New Upcoming Features | Post: 357446
Yours in not the first post about this.
IMO, this is an unnecessary 'feature' that will only cause problems and a higher support load.
It doesn't matter that columns I and J have become disorganized because we know where each item is, which is all we need to know.
Date Time Of Last Edit: 2023-09-20 00:28:46
[2023-09-20 07:26:35]
Sierra_Chart Engineering - Posts: 17190
By default that input is set to No. Updating Sierra Chart should not cause any problems with Spreadsheets.
The issue must be with this input:
Clear Unused Column I Names. We will make sure this is set to No.
We are putting out a new release now where this input is set to No. It should have been No.
There are backups of your Spreadsheet files which you can restore:
Working with Spreadsheets: Accessing a Backup Spreadsheet File
Date Time Of Last Edit: 2023-09-20 07:31:11
[2023-09-20 11:09:08]
sgne - Posts: 105
Well, I just checked, and both those settings were No. So, hopefully later updates won't mess with columns I and J. We'll see. And yes, I went to the backup folder and opened an older spreadsheet and restored the values, before I made the above post. I also frequently archive TSV files so I can get the formulas if need be, but backup spreadsheets work the best.
