Date/Time: Wed, 27 Nov 2024 04:43:55 +0000
6B detail data contract limited on foot print chart 1 min timeframe
View Count: 237
[2023-09-19 21:14:17] |
Misanirina - Posts: 39 |
Hi, i'm looking for to have more detail data volume contrat for british pound 6B in footprint chart 1 min. I don't understand why some people can see detail like more 100 contrats inside their number of bars 1min. Thanks |
footprint 1.JPG / V - Attached On 2023-09-19 21:10:10 UTC - Size: 72.31 KB - 92 views Attachment Deleted. |
[2023-09-19 22:22:21] |
John - SC Support - Posts: 36309 |
The data is the data. There is no reason for someone with the same symbol and chart setup (and data source) would have something different.
[2023-09-20 08:21:57] |
Sierra_Chart Engineering - Posts: 17190 |
Make sure Volume Filtering is disabled: Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu) And make sure you are using the correct symbol: Changing to a New Futures Contract Month Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
