Date/Time: Wed, 27 Nov 2024 04:32:58 +0000
Add aditional symbol - study does not show the correct symbol value
View Count: 228
[2023-09-19 17:35:30] |
User43 - Posts: 101 |
Hello, using the "add additional symbol" study I found that the additional symbol values are off. The attached picture shows on top MES (just ignore that), below I added MNQ via "add additional symbol", and then below that MNQ via "bar overlay". The "overlay" shows correct MNQ prices somewhere in the 15K price range. The "add additional symbol" shows MNQ prices in the 1.5M price range. Is that a bug in the "add additional symbol" study, or just a feature I don't understand yet? I know that I can apply a multiplier of 0.01 to the study to adjust the price, but why is that designed that way? Thanks Martin |
MESZ23_FUT_CME [CBV][M] 2 Min #1 2023-09-19 13_24_05.941.png / V - Attached On 2023-09-19 17:31:01 UTC - Size: 31.59 KB - 73 views |
[2023-09-19 19:25:32] |
Sierra_Chart Engineering - Posts: 17190 |
Yes you do need to use the Multiplier value of .01, and why the exchange quotes price in this format we do not know. What you are seeing is the exchange native pricing.
