Date/Time: Wed, 27 Nov 2024 04:45:43 +0000
Throttle Spreadsheet calculations
View Count: 239
[2023-09-19 15:04:00] |
User584005 - Posts: 27 |
I have an SC spreadsheet that I monitor to watch momentum on certain tickers. The problem I have with it is the data is moving too fast and making it hard to watch. Is there a way I can tell SC that for one of the columns of my choosing, only refresh the formulas every 5 or 10 seconds? |
[2023-09-19 15:24:05] |
Sierra_Chart Engineering - Posts: 17190 |
You can do this by changing the Chart Update Interval of the chart that is interacting with the particular Spreadsheet Sheet: Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-09-19 15:24:15
