Date/Time: Wed, 27 Nov 2024 04:50:05 +0000
Chart Trade Window Stop Offset Ticks
View Count: 255
[2023-09-19 13:42:30] |
User568539 - Posts: 18 |
In the Chart Trade Window, I cannot adjust the number of Stop Offset Ticks... no matter how many number of Stop Offset Ticks I enter in the Chart Trade Window under the "Targets" tab, on the chart, it always places my Buy and Sell Stops, 75 Ticks apart on the RTYZ23... 30 Ticks apart on the YMZ23... and 12 Ticks apart on the EPZ23. This happens on SC Version 2547, as well as on the current version, 2549. It occurs in both, Trade Simulation Mode and Live Trade Mode. I have tried it with "Type: Stop: Stop", as well as with, "Type: Stop: Trailing Stop". Thank you.
[2023-09-19 15:02:54] |
Sierra_Chart Engineering - Posts: 17190 |
The reason for this most likely is what is explained here: Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
