Date/Time: Mon, 16 Sep 2024 19:05:46 +0000
unable to open my CHT file
View Count: 197
[2023-09-19 01:12:27] |
User161116 - Posts: 1 |
Hi, I want to open one of my CHT file but unable to do that its showing (file not compatible contact support to convert it) so please help me with that |
[2023-09-19 16:55:25] |
Sierra_Chart Engineering - Posts: 16387 |
Refer to: Chartbooks (Workspaces): Opening Older Chartbooks Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
