Date/Time: Wed, 27 Nov 2024 04:31:41 +0000
Blank Message Log
View Count: 281
[2023-09-18 19:39:14]
user_xyz - Posts: 416
Odd had a separate instance of SC crash and close. Upon reloading SST trade copier says config error check message log. My message log is entirely blank - just in case I clicked the send for analysis.
I have two other separate instances of SC and those message logs are completely empty as well (even after restarts).
Also updated the separate instances with the SST error above to 2548 from 2544 and message log still blank. Had been working great for few weeks.
Date Time Of Last Edit: 2023-09-18 19:46:03
[2023-09-19 16:53:50]
Sierra_Chart Engineering - Posts: 17190
Make sure the Message Log is not disabled:
Window, CB and CW Menus: Disable Visible Message Logging (Window)
And check the colors:
Graphics Settings: Setting the Background Color, Text Color, and Font for Text Only Windows
Date Time Of Last Edit: 2023-09-19 16:54:20
