Date/Time: Mon, 28 Sep 2026 22:01:56 +0000
WIndows 7 will not let me uncheck read only to allow access. Video
View Count: 1954
| [2014-07-15 23:09:58] |
| User96392 - Posts: 2 |
According to the documentation I should unselect this so the program can acess my files, but if I try to do it, it just undoes it. Here is a video showing what is happening: https://www.youtube.com/watch?v=SU4HgO2n0R4&feature=youtu.be |
| [2014-07-15 23:41:26] |
It looks like Sierra Chart is installed in the Program Files folder? If so, that is the source of the problem. Sierra Chart will not function correctly there. Sierra Chart will write into its own folder and a subfolder and that is not allowed in the Program Files Folder by the Windows operating system. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-07-16 06:06:02] |
It seemed to me that you could install it there as long as you did not have the folder as read only.
| [2014-07-16 06:17:56] |
Perhaps, but clearly Windows is not letting you do that.
